Question about Philips Magnavox DVD/VCR Dual Player
Sony vhs player automatic tracking not working
What adjustments can be done
Unable to adjust tracking on VHS tape player
That means your alignment is out. Need to take to repair shop and have it realigned. Usually not a very costly repair. Hope this helps.
May 13, 2011 | Sony Televison & Video
How do I adjust tracking on Zenith vcs442 player?
You will need more than an owner's manual, you need a service manual. This is not something the maker expects a customer to adjust. It likely involves some screws near the heads--but don't screw it up or you might as well buy a new player. In fact a new VCR may be cheaper than a manual and smaller than your model, too. -Ken
Jul 27, 2009 | Zenith VCS442 VHS VCR
How do you adjust the tracking on the Sylvania SRD3900 DVD player / VCR combo? We are unable to watch VHS any longer because the tracking is so off. We are unable to find any tracking controls on the...
tracking should be automatic nowadays with VCR's, so you may have to have it professionally cleaned unless you know how to do it, most likely a store bought cleaner will probably not work.
Jun 08, 2009 | Televison & Video
VHS output is fuzzy
i think its the tracking adjustments.
May 27, 2009 | Sanyo HV-DX2E DVD Player/VCR
JVC DR-MV1S VHS Tracking
No manual tracking or if there is it wont help.either heads are worn or possibly dirty.if u open it .i assume u have.the silver drum has little notches around it.2 ,4,or 6 these are the heads.get some alchol or aftershave will do.take a peice of card playing card size is ok .must be plain not printed.apply some aftershave alchol to card not dripping ,hold card against the dum then with other hand turn the drum back and forwad not moving the card,u may damage heads.when u check card it should show some dirt reassemble and try.otherwise its museum time show the grandkids see if they know what a tape is
Jan 14, 2018 | JVC DR-MV1S DVD Recorder/VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Tracking adjustment
have you tried the following >
1)Get a head cleaner for the Vhs and run it
2) the next tim e you put in a casette it should adjust the tracking automatically you will see it on the screen as it is adjusting.
Sep 19, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
DVD-V3500 DVD player works fine the VHS does not display
Its problem of dirty / clogged video heads and can be solve by using VHS video head cleaning cassette.
Regards,
Sep 14, 2008 | Samsung DVD-V3500 DVD Player/VCR
Blue Screen
Could be dirty heads if you have a dry head cleaner tape try it (Maxell and RCA make ok tapes to try for ~:30-1min) ALSO:
There is a delay in the time you adjust the tracking and
the results being visable on the screen on this unit,
I suspect the tracking is adjusted off center. It takes some getting used to the way this deck's tracking adjustment works as the VHS video is upconverted to be captured onto the dvd and that is what you see, the upconverted video, fed out to your TV, analog or digital, this unit upconverts everthing to digital even analog channels, there needs to be a noise/blue screen off feature in the menu like my old hitachi VHS deck and my JVC ~$60 deck has now. On analog TV or old tapes it comes in handy for adjusting the tracking/antenna.
Feb 08, 2008 | RCA DRC8335
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
