Question about Bradford White M240S6DS2 40 gallon 240v Electric water heater
Heating element what is the wattage of the heating elements
4,500 watts.
Posted on Mar 10, 2016
I NEED A RHEEMGLAS HEATING ELEMENT FOR A 50 GALLON WATER HEATER
Heating elements are most all the same. take your old one to your box store of choice and get one same style and wattage. 1500-1500 that sorta thing
Feb 22, 2015 | Water Water Heaters
Checking ohms on whirlpool dishwasher heating element
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Rated voltage squared divided by rated wattage = ohms
Element rated for 240 volts and 3500 watts
240 x 240 = 57600
57600 divided by 3500 = about 16 ohms
Gene
Sep 09, 2014 | Water Heaters
What if I replaced a long heating element with a short one on my water heater?
Won't matter much... except long elements generally burn out less often than short ones since heat is spread across larger surface area .. assuming both elements are same wattage.
Lower wattage element will heat water less quickly by a few gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Sep 06, 2014 | Water Heaters
Can i use a 4500 watt on a 208 volt system
Yes
Voltage and wattage printed is on end of each element
If element shows 240V 4500 watt, then element Wattage at 208V is reduced to 3375 watts and will heat 16+ gallons per hour
If element is rated 208 and 4500w, then element will operate at 4500 watt and heat 20 gallons per hour
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Gene
Aug 11, 2014 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do I replace the heating elements in my Rheem water heater
Replace heating elements can be found at amazon, click here and take a look: Amazon com rheem heating element . I hope this was helpful... cheers
Jan 31, 2013 | Rheem 82V40-2 Fury Electric Residential...
What heating element do I need for a model 71-30s water heater?
Rheem 71V30 series water heaters use generic 4500 watt element from hardware store.
Look at label on side of tank for wattage.
Look for wattage and voltage printed on end of each element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Aug 05, 2012 | Rheem Water Heaters
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a rheem glas standard 30 gallon model # 81sv-30d water heater with upper and lower watages 3500. how do i know what size heating element i need?
Look on label on side of tank.
Wattage of tank will be element wattage. This is true if tank has one or two elements since both elements are never ON at same time.
Simply go to hardware store and buy 3500W element.
Take phone photo to store if needed for identification.
Wattage appears on end of each element.
http://waterheatertimer.org/images/Voltage-printed-on-element-.jpg
Feb 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
Is 30a sufficient for a 80 gallon electric hw heater
The wattage of the heating elements will determine the amperage you need. Take the total wattage of all the elements and divide it by the voltage you are using (probably 220). That will give you the amperage. Example: 4400 watts divided by 220 volts equals 20 amps.
Sep 17, 2009 | Water Heaters
Bradford White M240S6DS2 40 gallon 240v Electric water heater Logo
88 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
