Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
External HD not recognizing USB ports as being Hi-speed ports
All USB ports on my PC have been proven to be hi-speed ports via use with other USB mass storage devices. No matter which port I plug my SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive into, I continually get pop-up notice indicating that it is a Hi-Speed USB device attached to non-hi-speed hub and that it will function at reduced speed when plugged into a non-hi-speed port, so I need to disconnect from current port and then connect to another port. (1) Why am I getting pop-up? (2) Is device really functioning at reduced speed? (3) Is there a solution?
  • darcyqm Jun 15, 2009
    Why would a larger capacity mass storage device not give me the same problem when I plug it into the same USB ports of my PC? The fact that it doesn't makes me think the problem is with the external HD. No?
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Posted on Aug 14, 2009
Simpletech has confirmed this is a problem. They replaced two of my drives under warranty. The replacement drives work fine and connect at usb 2 speeds.
Posted on Oct 15, 2009
  • 523 Answers
Its your computer usb ports problem, there is an external usb ports can give u the high speed , go to any pc store and ask for usb cards high speed.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 14, 2009
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Windows 98FE will not see my USB corsair stick nor ext Maxtor USB
What you need is a USB mass storage driver, check out the following link for a download:
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Mar 12, 2009 | Computers & Internet
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
Hardware Malfunction Error
Hi, This is a common problem with external storage. Please refer to http://www.fixya.com/support/t191153-device_recognized Below is a copy of my response to a similar post. Based on your post/description: 1. Your PC does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the My Book itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options aside from running manufacturer's diagnostic and/or third party recovery software are: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct inside a desktop either as IDE or SATA; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 04, 2007 | Western Digital My Book Essential Edition...
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
1,238 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
