Question about Bosch AHS 45-16 Electric Hedge Trimmer
Bosch AHS 45-16 trimmer
I have severed the cable, can I open the body safely?
I cut the cable of my Bosch AHS 70-34 hedge trimmer.I have rewired it but it wont work,Alan
You must make sure you wired it properly and the connections are good
Sep 07, 2017 | Bosch Garden
What is the best way to sharpen bosch AHS 45 16 HEDGE TRIMMER
Please understand, if you do, you may well start a business!
You will have to take it all apart, and then take either a file or a grind stone and resurface the blades.
I know you can learn this skill, if you do not know how, but this time it will take you to do it right will be hours, and if you charge a reasonable rate to do this for others, you may find it cheaper to buy a new one!
You may be able to find a web-site by looking on-line that will tell you exactly you to do this.
God bless your efforts.
Jul 11, 2016 | Bosch AHS 45-16 Electric Hedge Trimmer
Where can I get a new cable fitted for this hedge trimmer?
any accredited electrician or appliance repair shop will be able to fit a new lead(cord)
look in your local telephone guide.
Jun 16, 2015 | Bosch AHS 45-16 Electric Hedge Trimmer
I have a Bosch hedge trimmer AHS 52 LI and yesterday when I tried to fit the battery to the trimmer it would not fit
Make sure that you are using the right battery, positioning it right to match how it goes the receptacle. Last thing is do not be afraid to give it a good push in there. New ones in particular have a firm seating which can take a little bit to get it in.
Feb 20, 2015 | Bosch AHS 52 Li Cordless Hedge Trimmer
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
AHS 4-16 Bosch hedgetrimmer. Where can I find an exploded schematic, or even a photograph of the internals? Thanks
Go to Bing on your computer type in what you need and they help you there look at pictures and tell you about it.
Sep 08, 2012 | Ace Hardware Garden
Cut Cable on Bosch Hedge Trimmer.
Been there. Done that. Now it is up to the "expert" to go back over the rewire job and find what's wrong and fix it. Oh yeah, I once used my hedge trimmer to shorten a brand new extension cord!
Jun 13, 2017 | Garden
Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Sep 19, 2009 | Garden
Bosch AHS 45-16 Electric Hedge Trimmer Logo
66 people viewed this question
Top Bosch Garden Experts
roeb
cwradio73
Are you a Bosch Garden Expert? Answer questions, earn points and help others
