I have a jamo mpa 101 amplifier and do not know how to hook it up
2 Suggested Answers
  • 137 Answers
SOURCE: I'm replacing a JAMO amp.
The 201 is 100w in to 4ohms and the 101 is 50w into 4 ohms other then that there the same
Posted on Apr 15, 2010
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
Where on my mixer should I plug the subwoofer into? Or would plugging it in somewhere else be better ?
This will depend on whether your sub-woofer is powered (has it's own built in amplifier) or not. If it is not powered it will need connecting to an amplifier. If it is powered you will need a line level output either on the amp or the mixer.
Many modern amplifiers (and some mixers) have a dedicated output for sub-woofers in which case this is the best place for it because the higher frequencies will have been filtered out.
Some high quality amplifiers like the JAMO MPA 101 have a filter switch and adjustable filter level for powering sub-woofers. You then just connect the speaker to the speaker terminals in the normal way.
Otherwise on a p.a. mixer you could use the main output, one of the auxiliary, monitor or sub-mix outputs. If you are not using the main output you will need to route signal to the appropriate output accordingly. Either way your output signal will cover the full frequency range - your subwoofer may have built in filtering or you may need to use some sort of crossover to split the signal between the sub-woofer and the rest of your speaker system.
Feb 25, 2011 | Audio Players & Recorders
Mar 24, 2010 | Jamo MPA201 2-Channel Amplifier
Jamo MPA-101 2 channel amp quit working
Check the small electrolytics on the power supply board for high ESR, Very common problem on these amps. Protect circuit stays latched due to high ripple from PS.
Mar 24, 2009 | Jamo MPA201 2-Channel Amplifier
Two Jamo MPA-101 amps not working
I can almost guarantee that you'll find bad electrolytic caps on the power supply board to be the cause of the problem. I've seen several of these with the same problem. The protect circuit stays latched due to excessive ripple.
Dec 16, 2008 | Jamo MPA201 2-Channel Amplifier
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
223 people viewed this question
 Grubhead
Grubhead
