Dixon ABMA3 serial number
Looking for serial number
Have a Dixon guitar model 62 serial number seems to be 75528. Do you know value?
its only worth what they will pay,it does not mean cheep.best bet is to take it to the shop see what they say then take it to another if they are close they have given you best idear ,ie
1 shop says 1600,2ns shop says 1500 you worth is 1550
Jun 16, 2017 | Dixon Music
I have a dixon bass guitar that was my mothers. I want to know what it is worth.
Dixon were mostly known for making knockoff copies of more expensive name-brand models. So which one does this Dixon look like? Or, what's the Dixon model number?
Have a look on Google at 'bass guitar' and see if you can find the lookalike. Then we may be able to suggest a value, but it won't be over US$300.
Apr 11, 2017 | Bass Music
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Why is my dixon zr22 kohler engine losing power when it heats up?
sounds like a fuel problem or its getting too hot, check your fuel filter for flow, then look to see if there is any thing blocking the air flow through the cylinder, clean and remove blockage, if problem persists after cleaning, replace carburetor.
May 18, 2014 | Garden
Where to find model number for a dixon kodiak ZTR
where is the model number or serial number
Apr 23, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
