Question about Staples SPL1524CP Strip-Cut Shredder
Somethibng, maybe paper clip stuck. Cant go forward or in reverse, cant pull stuff out. took pillips screw driver to open the bottom but after takingout all the little screws it won't release - as if
All details are above..Just want to know how to open the thing since unscrewing it won't release the casing.
Sounds like change grinding in spin cycle
This machine is prone to getting stuff down into drain pump. Pull unit away from wall, disconnect plug, hoses etc... Pull back steel panel of of rear of machine, facing rear of machine, drain pump on lower left, rinse pump on lower right, take needle nose pliers or spring pliers and remove hose to tub and drain pipe hose, tilt machine forward, take 5/16 nut driver and remove three screws holding pump, drop pump down, replace pump. Install in reverse order. Then, remove center nut in center of tub, pull center spinner out, then lift top to machine, remove inner tub and clean out metal, money or other stuff from bottom of outer tub, reinstall in reverse order.Once money has gotten into pump it can damage it, so replace it even though it looks good.
Oct 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cd stuck in compter and cant eject manually despite paper clip method. this packard bell computer
Try restarting the computer, and insert the paperclip while the LED light flashes in your CD drive when the computer restarts..
Apr 18, 2009 | Computers & Internet
My Inglis top loading washing machine is leaking. I would like to take the back off to see if I can find the problem....how do I do that?
two screws at back bottom corners of control panel unscrew all the way but they should stay in then pull bottom of control panel just grab where screws are at same time and pull forward. then take a screw driver (flat head) there are two metal clips gold colored take them off by using screw driver and pusning forward on clips to release them then unplug door switch black plug three wires then lean cabinet forward and pull it off top front and sides will all come off then check for leaks
Mar 07, 2009 | Washing Machines
Computer cant read printer
now i got to pay yall to fix the **** i cant see that
Jan 08, 2009 | Lexmark Z2300 InkJet Printer
Cant open acces panel on washer
no panel to pull off ..remove 2 screws on rear of console ..pull console forward and roll back ..clip each corner remove and lean cabinet forward and lift off ..pressure switch hose is right rear and runs up back to console
Aug 28, 2008 | Whirlpool LSR7333 Top Load Washer
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
How do I open my washing machine to check the pump
First unplug the washer,
then remove the control panel, usually two screws on the bottom of panel. Panel usually then pulls forward and then flips up and over.
the cabinet is held to the back panel with two clips one on each side, remove clips with a screw driver prying them out. On you model you may have a few wires to unplug or hoses to disconnect, maybe not. cabinet pulls away however it is tabbed on bottom front, make room for it.
Pump is located on lower front of machine, have towels handy because it will have some water in it. If tub has alot of water in it Bale it out first.
Jul 12, 2008 | Whirlpool Washing Machines
Cylinder seal
for most dryers,
Unplug dryer
remove old felt
allow glue to set
Jun 04, 2008 | Maytag Dryers
Shredder suddenly runs only in reverse
Sounds like the sensor/switch that detects when the basket is full of clippings is stuck in the "full" position. UNPLUG this potential finger-eater and poke around on the underside with a pencil or something.
Feb 27, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Staples SPL1524CP Strip-Cut Shredder Logo
87 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
