Question about Marantz SR-48 Mark II Receiver
How do i program the channels on my sr 48 mk2
How do i imput stations
I NHAVE A TERRIBLE HISSING SOUND ON MIC IMPUT 1
With a mic plugged in, or with the input open? With the channel volume up or not?
Jul 01, 2016 | Numark Industries Numark KMX02 Dual Deck...
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
I just lost all my digital channels. The problem started yesterday and continued today. When I changed to a channel the TV would give off a load crackle sound and the picture and sound would disappear....
this is what i can tell you your tv has 2 boards a main one and a power supply one anything that has to do with your imputs tv, av, hdmi, etc has to do the main that includes the picture going off and sound you can contact the manufacturer and tv technicians, but the only place that its going to be cheap its at www.shopjimmy.com guaranteed
Apr 13, 2010 | Element Electronics FLX-2610 26 in. LCD...
Lost remote want to get to input channels using side buttons on TV
Try using the manual buttons and keep pressing channel down until you see the lowest station you receive, then go slowly.
Maybe Insignia put the inputs into the channel search automatically.
Apr 27, 2009 | Insignia LCDTV26 26 in. Television
Setting radio stations
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
BC
May 23, 2008 | Pioneer DEH-P2000 CD Player
Imput channel or imput switch
if you scan down below channel 2 doesn't video show up? otherwise there should be a input / video button
Dec 31, 2006 | Zenith B27B40Z 27" TV
Marantz SR-48 Mark II Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
