Question about Polaris 2010 Rush 600
Polaris problems recently rebuilt my top end now when it is running it cuts down to one cylinder when it reaches temp. what should I check
    Champion:
    New Friend:
  • 220 Answers
Check for a clogged main jet in ur carb.
Posted on Oct 02, 2014
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Why are so many trouble diagnostic codes being thrown
sounds like you speed sensor and your throttle poistion sensor
Sep 02, 2014 | Cars & Trucks
Polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
Rebuilt top end 30 over and now it starts fine but will not idle down...... what should we do?
Check the throttle freeplay, should be about 1/8 to 1/4 inch freeplay on the throttle. That would be probably the first place to start. Also if it will not idle down it could be an air leak in the carburetor intake. The rubber boot can develop cracks and **** air in after it is mixed in the carburetor causing a lean condition, this can also cause the atv to not idle down. Let me know if you need any other ideas, Daniel.
Sep 11, 2011 | Polaris ATV
Hi,redone the top end of my Rm125 1989,it struggled to reach powerband for a while, but eventualy it reached it!Next morning I started the old lady and there was almost no compression with a funny noise in...
Hi, i presume that before you rebuilt the top end you had no issues? Normaly this happens when either you have exsessive play in either the big end or the small end bearing, this would be recognised by up and down moovment in the conrod for big end and piston for small end, this would account for spark plug contact only. The other thing to check was the piston identical in height to the old one, did it have the same cut outs for fuel transfere, and finaly did you install it in the correct direction with the rings located in the peg positions facing the inlet side of the barrel, was the new head gasket the same thickness as the old one, did you run i the new piston for a while if the piston and cylinder were new a bed in period must be observed
Mar 13, 2011 | 2003 Suzuki RM 125
Polaris 300 it will run get loud and die
2 strokes get loud before they run out of gas. check your fuel lines and carb to see if your getting enough fuel to the engine.
Dec 17, 2009 | Polaris ATV
Sportsman 800
HELLO;Yes if the motor wasn't rebuilt with a piston of lower compression than your running at a higher level and you might look at rejetting the carb and also checking the timeing. GOOD LUCK......GREASY.
Aug 24, 2009 | Polaris ATV
Polaris rmk 500 backfires when it gets hot then won't start
Ok this sounds like a similar problem that I have had with a 500xc engine...This engine has been running fine for the last 5 yrs until a few weeks ago when it became a pig to start and when it did only run on one cylinder eventually running on both and when it gets to a certain temp would cut out and then not start again for 5mins, changed everything we could think of, checked compression, barrels fine, carbs clean new cdi, coil, plugs, leads, fuel pump and pipes, then someone came accross with checking the resistance on the temp sensor on the top of the head which were different values to the the book and on another identical engine, I borrowed a spare sensor and although still a pig to start it was an improvement when running, need to buy a new sensor to rule it out
, can anyone else shine some light on this?
Feb 20, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris 2010 Rush 600 Logo
395 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
