Question about Marantz SR-48 Mark II Receiver
How do i program the channels
How do i enter stations to the memory
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How do I enter stations into memory and then recall them?
First select your station by scanning,than press memory button,while it is flashing select your preset channel thru preset buttons that you desire to have it and push memory button again.(you must act quickly otherwise flashing stops that you need to start from zero) .your channel is now in the memory.To recall ,simply press the relevant preset channel..good luck
Jan 12, 2010 | Audio Players & Recorders
How do you set up the scanner to scan police and ems channels
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Jan 11, 2010 | Uniden BC340CRS Base Scanner
I have an RX-DT680 unit on which i am trying to set the preset FM Stations to and am wondering what I have to do to accomplish this?
1. Select desired channel 2. Press " tuning memory" until "program" flashes 3. Press " preset tuning" up or down to select position 1-10 4. Press " tuning memory" again, flashing " program" disappears 5. Channel is now selected @ position 1-10 6. Find channel @ selected site by pressing "preset tuning" up or down
Oct 02, 2009 | Panasonic Audio Players & Recorders
How do you set the radio stations?
With my ilive ish3 soundbar, you find an unused memory preset, go to the station you want to program, press MEMORY and while the display is still flashing press MEMORY again. Took a bit of trial and error to figure that one out.
Jun 12, 2009 | Apple iLive IBCD3816DT Portable 2.1...
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
Marantz SR-48 Mark II Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
