Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
The touch screen is not functioning properly. I
The touch screen is not functioning properly. I have to press real hard for an extended period of time to get it to respond.
  • Garmin Master
  • 2,130 Answers
Please see this link. It probably needs to be replaced.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Apr 19, 2010
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Minolta bizhub 200 Copier
Tip
How to renew an iPod Touch AIM
<p>The iPod Touch's built-in wireless adapter lets you operate the equipment for the Internet functions based on multiple, including the use of instant messengers such as AOL Instant Messenger. As your computer, your AIM buddy list is usually updated automatically to reflect their friends in real-time signals. If not, manually update AIM to see who is online and available to chat. <br /> <p><br /> <p>1. Connect your iPod Touch to the Internet. Touch the "Settings", then "Wi-Fi and tap the name of a nearby network -. Enter a password If you need one - and tap" Join ". <br /> <p><br /> <p>2. Touch the "App Store" application and click the "Browse" button in the lower right corner of the screen. Tap your finger on the type of the "Search" on "AIM" and tap "Search". Tap the "Install" button next to the MSN application to install it on your iPod Touch, if you have not done so. <br /> <p><br /> <p>3. Open the "target" application and enter your username and password. Touch the round "Arrow" button in the upper right corner of the screen to manually update your list of friends. <br /> <p><br /> <p>4. Press the iPod touch "Home" button to close the AIM and then again on "AIM" icon to reopen if the refresh button does not work. As is the case with AIM on your computer, the AIM application for the iPod Touch periodically stop working, especially if it is open for a long time. <br />
on Jul 21, 2011 | Computers & Internet
CANON IR6800CN ERROR:E000078-000; HOW CAN I REMOVE IT IN ORDER FOR THE MACHINE TO WORK PROPERLY.
you can follow this steps
press additional function 2 , 8 and additional function
then touch on copier,
touch in function
touch on clear
touch on ERR press ok.
touch on DCON press ok
touch on RCON press ok.
press reset button 4 times
and restart machine
Apr 11, 2011 | Canon imageRUNNER C6800 Copier
The frame of the refrigerator is hot to the touch, unit is still functioning properly
Those areas need to be warmed to prevent condensation from froming there. Older refrigerators used a low wattage electric heater, but now, in order to conserve energy, some of the waste heat from the refrigerant system is used, which can result in warmer temps there, especially if the frefrigerator has been running for an extended period of time.
Dec 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
May 25, 2009 | Garmin Nuvi 660 GPS Receiver
Touch Screen fails to work
get it serviced?
my guess, damaged screen.
most shops would touch any Ipaq.
why not ask on a real HP forum?
my guess, the only hope for old Ipaq
http://h30434.www3.hp.com/
May 10, 2017 | HP iPAQ hx2190 Pocket PC
Touch Screen
Hi Blu,
A friend had a similar problem, with the touchscreen not responding at all. I read somewhere on the internet that if you press the four corners of the screen very hard with your thumbs it may come back. I tried it...and it worked!
Phiv.
Jun 25, 2008 | HTC Touch P3450 Smartphone
Image Runner 400
The touch screen needs calibrated in service mode
It is easy to press buttons you shouldnt when in service mode which can cause an expensive service call. Do you have experience working on Canon copiers?
I can help but do not want to cause serious problems...
Nov 30, 2007 | Canon imageRUNNER 5570 Copier
GPS Logo
102 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
