Question about Pioneer DVR-220 DVD Recorder
Won't power on
After a brief power outage unit won't power on
Air conditioner won't come on after power outage
i would suggest looking for a hidden reset button on the unit or check any fuses/trips connected with it.
May 30, 2012 | Heating & Cooling
Hello!WE had recent power outage ,now door opener won't work.unit has power lights come on when remote pad pressed,but nodoor action?thank you
Along with the power outage you probably also had a power surge. You need to pull the logic board and check the printed circuit board for burnt or missing traces. Unplug the unit first.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello i hava aq-see qt426 surveillance system and after a power outage it won't boot, keeps rebooting and freezes on 'system initializing" screen. do i have to format the HD or it could be...
you need to format the HD. The sudden power outage is the reason the unit is freezing. As a matter of fact, the HD is the cause of the freeze. The HD has not been able to recover from the sudden power outage.
Format the HD and hopefully the unit should be back to normal.
But if unit is not in order after formatting the HD, please let me know for further direction.
Good luck.
Jun 23, 2011 | QPS Q see QT426 Video Surveillance System
Toshiba dkvr60ku DVR VCR combo unit is totally dead, following brief power outage
Check the fuse inside the unit around the power supply area.
Dec 21, 2010 | Televison & Video
Dishwasher won't power on.
We're having the same trouble. What eventually happened?
May 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
We had a brief, about 5 seconds, power outage now our Intertherm electric furnace is turning on and off repeatedly. The temp was set at 65 and I turned it down to about 60 and it has stopped. Could that...
Hi, is this furnace a free standing unit or a full size electric heater? You can try turning off the main power to this heater for 5 or so minutes and back on again. You may have lost a internal stat of some kind. Try what I said and if nothing changes, send me the model and serial number so I can check into this further. If it stopped at 60, it should be alright at 65. The thermostat may have burned out. I don't know this yet but let me know what happens.
Shastalaker7
Apr 14, 2010 | Heating & Cooling
We had a brief power outage--now prinker knunks
In all probability that Power Outage caused a massive Spike or Surge on your power line. This has affected this unit. It doesn't take much to cause this type of thing and is quite common. It may be repairable, however these days buying a new one is often a better option. If you do go the repair route, go to a reputable place, & please ensure you get a firm "Quote" not an "Estimate" for repair.
Jan 20, 2010 | HP Photosmart 2410 All-In-One InkJet...
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
After a brief power outage, our Wii will not turn on.
It probly short circuted or somthing..Unplug it w8 a couple hours then plug it back in and try again..it might not work ever again if it was turned on durring the power outage
Nov 07, 2009 | Nintendo Wii Console
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
22 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
