Question about Camping, Backpacking & Hiking
How do I freeze Brussel sprouts
How do I put fresh Brussel sprouts in the freezer to keep
4 Suggested Answers
SOURCE: Fresh food compartment not cooling. Freezer seems to be working
Evaporator coils iced up- either bad bi-metal thermostat,heater or board.Check resistance on thermostat/heating element.If reading resistance try and jump board into defrost mode by jumper wire from l-1 to defrost lead.
Posted on Sep 16, 2009
heatman101
  • 43501 Answers
SOURCE: cooling issue
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 18, 2010
imufo2
  • 3773 Answers
SOURCE: freezer doesnot freeze, fridge doesnot
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 20, 2011
How to lower my potassium count
There are foods to control which are especially rich in potassium
- avocado
- white beans
- spinach, brussel sprouts
- baked potato with skin
- apricots
- yoghurt
- salmon, tuna
- white mushrooms
- bananas
- peanuts and peanut butter
If you reduce intake of these it is a good start. You may not have to cut them right out.
http://www.kidney.org.uk/help-and-info/medical-information-from-the-nkf-/medical-info-other-potassium-lowering/
Jan 07, 2017 | Cooking
My freezer keeps already frozen food frozen but wont freeze fresh food
You need to put it at the top of the freezer in an upright freezer which is usually where the circulation fan is. With chest freezers you put them in the bottom. You may be able to make the freezer colder by turning the thermostat dial to a higher number. The higher the number the colder the compartment will be.
Get yourself a cheep fridge and freezer thermometer from Walmart. They have a green section where the red line should be. The freezer should be minus 18'C or 0'F.
http://i.walmartimages.com/i/p/00/07/23/97/00/0007239700696_300X300.jpg
Nov 03, 2015 | Freezers
How doe I freeze fresh peaches
Blanch them in boiling water 1 minute, then dunk in ice cold water to peel. Cut them up removing the pit, and lay out in a single layer on baking sheets. Place in freezer for a day, then transfer to freezer storage bags and store in the freezer.
Sep 11, 2014 | Home
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
How to freeze fresh strawberries
Wash. take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
you can blend them and put into a ice cube tray as a great way to add flavour to a fruit smoothie - keeps it cold without watering it down.
Mar 25, 2014 | Cooking
Aside from the 'normal' variations of fish food, is there anything else I can feed them; perhaps some human foods?
This really depends on the types of fish you have. There are some items you can buy at your grocery store such as lettuce, peas and brussel sprouts that your herbivore fish can eat.
Aug 29, 2012 | ANIMATE Fish
I have some suggestions on making Farmville better. More crops like Radishes- white and Red; Sprouts- Brussel, bean and Alfa Alfa. There are more crops but i can't think of any more right now. Also, If we...
I would talk it up with the administrators of the application itself. Facebook has no affiliation with that application. You can talk to them admins. of the app. on that application's page.
Jan 14, 2010 | Facebook Social Network
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Camping, Backpacking & Hiking Logo
65 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
