Question about Samsung DV306LEW Electric Dryer
My Samsung DV306LEW stopped heating. I took it apart and found that if was full of lint. Not sure how to check heating element and/or thermal fuses.
Not sure where thermal fuses are located. I do have a multi-meter
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
All you need to do is ohm them out if you get 0 it is bad if you get infinity or peg the needle it is good
Posted on Mar 24, 2014
My dryer suddenly stopped drying today. It just blows cold air. Before I took notice of all the lint in dryer, I took the heating element coil out which doesn't look damaged.
The lint MAY have caused a thermal limit fuse to blow out. If that is the case then it has to be replaced. There is also a chance that the heater element has failed and as you saw it is like a light bulb coil. You need to inspect it very closely if you don't have an ohm meter to test it for continuity. Frigidaire 131553900 Heating Element Assembly PartSelect
and
Frigidaire 134120900 Thermal Limiter Limit 220 PartSelect
Dec 18, 2017 | Frigidaire Dryers
Why did this part fail again?
this fuse usually blows when the dryer gets too too hot. It is there to pop before your dryer starts a fire internally!!! Make sure that your element is good and not sticking (meaning the element popped and stuck to the housing causing a false connection for the coil to run through). if that isn't the problem then make sure your dryer vent in the back is not clogged up and air flow is not blocked!!!
May 21, 2014 | Samsung DV306LEW Electric Dryer
Dryer no longer hot
Could be the element, thermal overload, loss of one leg of the AC supply, a burned off wire or timer. Do you have fuses or circuit breakers? If you have breakers reset the breaker and see if the heat works. If you have fuses check each with an ohm meter. One leg of the 110VAC will run the motor but you need 220VAC to make the element heat. (that is if this is a 220VAC dryer).
Jan 06, 2014 | Samsung DV306LEW Electric Dryer
Dryer won't heat.It is not the element , thermostats or thermal fuse.When it stopped heating,I used it for a while on air just to fluff.After having everything checked we found that the lint filter housing...
If you are sure thermostats and fuses are good (most dryers have 4) and its not the element, then the heat circuit also runs through the motor and timer.
Oct 17, 2017 | Roper REX3614KW Electric Dryer
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
I have a DV306LEW/XAA dryer that is about 4 years old. It now has no heat. It is tumbling ok and the blower is working fine, it just blows cold air. I opened the small lint hose cover a vacuumed everything...
There is a thermal shutoff on the heating assemly that will turn off the dryer heat. Also, we just experienced a fire in ours due to lint build up in the body of the dryer even though we vacuumed out the lint trap on a regular basis. To look in this area, you have to take the top off the dryer and then the front. You can look by pulling out the dryer outlet connection and a flashlight. Make sure to put it back in correctly though to avoid a fire.
Nov 22, 2009 | Samsung DV306LEW Electric Dryer
No hot air
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 15, 2009 | Dryers
Drier does not dry or blow heat
IF this is a Gas dryer, check the following.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If this is an electric dryer, check the following.
2. Heating element
3. Thermal fuse
Additional Checks.
Venting
Jun 06, 2009 | Whirlpool Dryers
Runs but no heat
If you are sure the element is fine use a multi meter to be sure you have continuity from the element back to the timer there could be a thermal fuse. Be sure you have 120V and 240 volt at the plug. If there is a seperate heat setting switch check continuty there. If all is good there chances are it is the timer itself. Normally the dials inside will wear and they will no longer push contact on the micro switch to turn on the element. You can test this with continuity by going from the power into the timer and to the element, have someone spin the timer by hand. You may find it jump when the odd contact is made but it will likley not be consistant. Some timers can be pulled apart and a tiny glob of epoxy on the right contact point will extend the life of the timer by a few years.
Jan 02, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Samsung DV306LEW Electric Dryer Logo
99 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
