Question about Rival Seal-A-Meal VS106 Vacuum Food Sealer
RIval VS106 wont heat up. Vacuum fine, wont heat
All the sudden it stopped heating up. the vacuum works fine, wont heat, so wont seal.
SOURCE: S16RB Rival Electric Skillet
As stated by a previous poster (rlorenson2) "There's a button on the base that is depressed by a nob on the pan.
Sometimes the button gets stuck and the safety feature kicks in and it won't heat up." My Rival Electric Skillet had been used maybe 6 times when it stopped turning on.
Based on rlorenson2's info, I pulled the base out and depressed the button 10 or so times, pushing it down and letting it pop back up). It did not appear to stick, and it was not dirty or sticky. But when I tried the skillet again, it worked fine!
Posted on Jul 12, 2009
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
  • 3 Answers
SOURCE: stopped sealing the bags, does not vacuum 3 week
Did the clip break that holds the sealing nozzle in place? If so, use a chopstick to hold the lock and seal unit in place. I place a little scotch tape on the chopstick, place it all the way across the sealing nozzle. You may have to really press on the lid to shut it, but it works. If it's not the clip, maybe you have a blocked hole or the sealing unit needs cleaned out really well. Good luck!
Posted on Jul 13, 2011
mechanicsonl
  • 431 Answers
SOURCE: instruction manual for rival food vacuum sealer model# FSFGSL0150-015
easiest solution is to visit manufacturers website
Posted on Feb 15, 2012
SOURCE: rgst902 no heat of food part on rival microwave
Check for a Fuse
Posted on Mar 30, 2012
Where can I find Teflon tape to cover heat strip on seal-a-meal vacuum system. Model vs106
Firstly, visit their website and look for a spares service. Ordinary Teflon plumbing tape MIGHT do the job but I'm not too sure how you would go about fixing it into place.
Mar 24, 2015 | Kitchen Appliances - Others
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
You can fix it yourself for $3 or so if you look for the thermal cutoff (a resister looking device) You can get this at a quality electronics supply. If you just cross the cutoff it will work but could be a fire hazard.
Oct 12, 2013 | Rival Seal-A-Meal VS106 Vacuum Food Sealer
Unit will not heat and Hand free light will not come on.
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
Good Morning, I have a Rival-Seal@Meal Vacuum Sealer Model # VS106/-B....Problem I am having is, it has stoped sealing the bag....Heat strip is not hot at all....Can you help me.....I purchase it just...
I have seen many complaints about those things come to FixYa...It seems that the wire that makes the heat either becomes disconnected or breaks...as far as I can tell there is no fixing or replacement for that.
Wish that I could give you better news.....:-(
heatman101
Sep 20, 2010 | Microwave Ovens
How do I make vac bags out of my roll for my VS106/b
I believe for the Rival machine you cut some of the roll, then seal one end. Put your product in the roll then seal the other end. Generic rolls can be found at http://www.totalvac.com/tiliafoodsaverrolls.html
These will work on a Rival machine.
Jun 14, 2010 | Vacuums
My Seal-a-meal won't heat up to seal the bag. The motor works and the ''hands free'' light comes on, but the heating strip is cold to the touch.
just bought mine - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Jan 08, 2010 | Kitchen Appliances - Others
Seal-a-meal won't seal
Take apart and see if wires are connected That is what was wrong w/ mine. Soldered wire now works fine.
Mar 30, 2008 | Vacuums
Rival Seal-A-Meal VS106 Vacuum Food Sealer Logo
114 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
