Question about ASUS FonePad
Battery level 0
Battery level always showing 0%. Tablet works fine, only not knowing the real battery level.
  • 1 more comment
  • Sorin Stanciu
    Sorin Stanciu Mar 24, 2014
    That was my first move. I even Reset Default from factory. For the moment is working normally but the icon(s) for the battery, Battery Doctor, the tablet itself from the settings, it shows 0% level. There is an update of the OS, which needs the battery full in order to updated, and I can not. Is still in warranty, I am thinking to detach the battery , but I don't know how to open the lid.
  • cwradio73 Mar 24, 2014
    Dont take chances here if warranty is good let them have the trouble. I think CMOS as well. Be safe here dont cost yourself.
  • Karl Whisenand
    Karl Whisenand May 07, 2014
    sounds like you might be using the wrong charger
  • 1,162 Answers
Have you tried shutting it down completely an then restarting. It solved my problem
Posted on Mar 24, 2014
Why is my tablet showing a 10% charge while its plugges into the wall-but as soon as i unplug it-it powers off- as if it was never charged?
Q: Cannot turn on the device
A:You cannot turn on the device when the battery is below the critical level, please charge the battery via the AC charger, then you can try to turn it on again while charging...
Tablet FAQ hkc
May 20, 2015 | HKC P776A - 7 8GB Dual Core Process
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
How come sometimes my screen works real slow, or not at all. but when I restart it the screen works gust fine,
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
Sep 19, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Windows date/time does not persist across shutdowns. It must always be reset
Sounds like a CMOS battery problem, assuming the internal power battery is working fine. May have to get someone to open your tablet PC to replace the battery (cmos)
Nov 20, 2013 | CTL 2goPC Tablet
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Le pan tablet wont charge how to reset
Le pan tablet not charging after all night does not show battery when plugged in.tablet does turn on battery level about 30%?
Apr 28, 2012 | Tablets & eReaders
ASUS FonePad Logo
70 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
