Question about Keurig Elite K45 Coffee Maker - -
My k45 does not make strong coffe
Is there an internal pot that I can adjust?
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Water will not pass through seems clogged
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Apr 24, 2010 | Cuisinart DCC-1200 Coffee Maker
Wavetek 320B Multimeter Calibration procedure needed. Specifically what do the 6 internal calibritation pots specifically adjust. The circuit board has these numbers: MD-HD110 & 33-5205F & 9917....
Wavetek 320B Multimeter Calibration procedure needed. Specifically what do the 6 internal calibritation pots specifically adjust. The circuit board has these numbers: MD-HD110 & 33-5205F & 9917. The calib. pots have these numbers: R06x, R031, R021, R23, R45.
vf2212@yahoo.com
Nov 25, 2009 | Meterman Wavetek VT101 Voltage Tester;...
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
HAVE LOST MANUAL. HOW DO I CLEAN IT
You will need the de-liming tool to proceed. Run a pot of white distilled viniger thouth the coffe maker. Viniger is a excellent cleaner & will not hurt any internal parts.
Jul 28, 2009 | Bunn 10 Cup Home Coffee Brewer
I have a cooks coffe maker (from JcPenny) my coffe
Wal-Mart,  BI-mart, Target, K-mart those kinda stores usally have them. or you can find the cook web site and try that.
Apr 20, 2009 | Cook's Essentials Cooks Essentials Arome...
Delonghi coffe pot DC312T --can't find a replacement carafe. Sams Club doesn't have them anymore.
I threw out the coffee pot. The replacement carafe was more expensive than the entire coffeepot!
Apr 17, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, and thank you.
Mar 05, 2009 | Bunn A10 Coffee Maker
Braun Proaroma coffe pot wouldn't brew
I found on online operater's manual for this coffee pot and solved the problem.
Aug 21, 2008 | Braun Aromaster KF 12 Coffee Maker
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Keurig Elite K45 Coffee Maker - - Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
