Question about Essick Air Humidifiers
Ea1201 fan speed wont work
Fan speed wont work, on setting 1 0r 2
MA-12010 comes on but will not stay on
my regservo need to active plz help me for activation code
Dec 29, 2013 | Emerson Humidifiers
Power light is on, water is up to fill line, dials are set to max humidity and fan speed, but fans do not spin. Tried to spin fans manually but they will not spin on their own. Left fan stopped spinning...
Do the motors feel warm-- maybe even HOT?-- Like they have electric current, but the bearings might be seizing up?
You mentioned one stopped spinning awhile ago--- and the other one was OK-
It sounds like the bearings are dry and worn on the fans-- (How old is the humidifier?)
The bearings CAN be cleaned up and lubricated, if you are into tearing a motor apart, and servicing the bearings-- Are you ready for that? You will have to remove the motors from their mounting, remove the fans, split the end bells, and clean and lubricate the bearings deep inside.
Let us know how much further you want to go-
Mack B
Jan 19, 2011 | Kenmore 14416 Humidifier
Output/Fan will not turn no matter what setting the speed control dial is on. Blue light and green light go on when humistat knob is turned. I purchased this humidifier in November and it was working...
Sorry to read about your problem, I hope this helps you out.
You either have a defective power switch, or defective motor, your unit is under warrenty, so I suggest you return it..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Honeywell HCM800 11 Gallon Humidifier
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
J-
I had this problem several years ago. In order for the water to flow, the outside temperature sending unit must indicate to the controller that it is less than 60F. If not, the unit will not operate outside of test mode. Check the temp outside where your sending unit is (could the sun be heating that side of the house?) and ensure that the circuit to the sending unit is working. I had a bad wire splice inside a wire nut stopping the circuit. Took me a long while to figure it out.
If the outside temp and your sending unit circuit is ok, I wish you luck on your troubleshooting.
adx_98
Nov 10, 2008 | Aprilaire 600 Humidifier
IFC on Trane furnace
If the manufacture says it is the IFC then you should have the IFC checked by the company who installed it if it is under warranty still
Jun 06, 2008 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
74 people viewed this question
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
Rabbit Brains
Rabbit Brains
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
