Question about Winsor Windsor SENSOR S15 Vacuum
Can't open the exhaust filter cover on Windsor S15 vacuum
Open exhaust filter cover
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
How do I open Dyson DC7 to clean filter
The only filter you can clean is in the compartment beside the dust bin, push in on the release catch to pull out the filter holder. This filter should be replaced occasionally. There is an exhaust filter under the cover the dust bin sits on. This filter should also be replaced occasionally.
Jun 13, 2014 | Dyson Filter DC7
Why does my dirt devil swerve get really hot?
Hello! Sounds like your vacuum may be overheating. This is usually caused by either a clog or a filter that needs to be cleaned. Please try the steps below to get your vacuum back up and running.
1. Remove the hose from both ends by pressing the release buttons.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the nozzle from the cleaner by pressing the release button and pulling the nozzle from the body.
4. Use a wooden spoon or something similar to loosen up and remove any clogs from the nozzle or the lower tube.
5. Remove the dirt cup. Lift open the lid to the dirt cup.
6. Remove the filter from dirt cup. Remove the filter frame from dirt cup. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
7. Check the exhaust filter by twisting off the filter cover.
8. If dirty, the exhaust filter can be washed as well. Hold filter under running water to rinse. Allow 24 hours to air dry.
This should stop the vacuum from overheating. If not please reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Thanks!
May 27, 2014 | Dirt Devil Swerve Upright Vacuum
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Cannot find filter in bag compartment
If you're looking for the exhaust filter, it is on the top of the machine under the crevice tool and dusting brush.
If you look at the rear of the machine you will see a tab on the attachment holder.
Remove the attachments on the unit
Push tab on rear of vacuum on the attachment compartment
Lift cover and your exhaust filter should be exposed and should just pop right off for replacement.
Mar 03, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Getting mist thru exhaust...according to your website i need to take out the filter...how do i do that?...i have craftsman model wetvac that doubles as a bllower..thanks
Pull the blower out from the lid. flip it over and your should see 3 or 4 screws that hold the filter cover on. remove those screws, remove the filter cover, then remove the filter. It is a dirty job. Most often the filter can be beaten clean. Some are washable. Clean or replace then reinstall. Good luck!
Jun 10, 2011 | Craftsman 17765 Canister Wet/Dry Vacuum
I want to know easy way to change my filter
There are only two. One on top and the paper cone filter that covers the entire base of the top. There are three paper tabs on the large paper cone filter. You can either put the filter directly on the bucket and then bend the tabs over the outer edges of the bucket to hold it in place and then sit the top down ( that's how I do it). Or you can put the filter on the plastic cone shaped frame on the bottom side of the top of the machine. It's actually easier if you flip it upside down and then flip the bucket base over onto it.
The only other filter is on the very top of the machine. Unscrew the top lid which is actually the cover for your exhaust hose inlet. This filter is indexed with a couple of screws that don't have to be removed. Spin the metal cover and remove filter. There is actually a large round filter ( hoop shaped on the top of the machine...I can't remember how I remove it, but truthfully it has little air restraining capacity so unless you have an odor issue with your Majestic what you can do is blow it out using the hose connected to the top of the machines exhaust blower outlet. Don't ever remove that filter, just literally leave it where it's at and put on your crevice tool and aim it through the slots around the top of of the machine.
Oct 01, 2009 | Filter Queen Majestic Canister Vacuum
No suction beam serenity plus
You may need a new filter bag part #110346. They can cause suction problems at the unit. Either that are there is a problem with the motor, does it sound alright when running? If not, take it to a beam repair shop, with proof of purchase, the motor would be under warranty for the part only, not labor. The filter bag is not covered by warranty.
Mar 26, 2008 | Beam Industries 2775 Serenity Plus Central...
Winsor Windsor SENSOR S15 Vacuum Logo
22 people viewed this question
Top Winsor Vacuums Experts
Are you a Winsor Vacuum Expert? Answer questions, earn points and help others
