Question about FreeMotion Exercise & Fitness
Home screen will not load
Can i reset to default
Phone freezes cannot do a factory reset
May I assume you have already tried a "hard reset"? (There are several easy-to-follow instructions posted on YouTube - just search for "Galaxy Y hard reset"). If so, see below. If not, know that the key part is to remove the battery before proceeding. If you're really lucky, the phone will boot up normally and everuthing will be fine; if not, the hard reset procedire, if it works, will boot up a factory reset device, which will PERMANENTLY wipe all apps and data from your phone. But at least the phone may work. If, however, the phone won't even begin to boot after removing and replacing the battery, your phone is - sadly - most likely "bricked." It may be revivable using professional tools, or at least the data may be recoverable, but it is probably not worth the considerable expense! Instead, it would surely be time to move on to a more modern device, such as the S4 or S5. Hopefully, your data is properly backed up, so it can all be loaded onto your new device. If not, you may be SOL...
Sep 06, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
Ti 92 black screen
In the HOME screen press [2nd][6] (MEM)
In the new scree press F1
Select what you want to reset. First try default.
Jul 03, 2014 | Texas Instruments TI-92 Plus Calculator
Reset bios
  • Restart the system. Click on "Start," "Turn off Computer" and "Restart."
  • At the Dell loading screen Tap "F2" to enter the BIOS. "Entering Setup" will appear. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  • Once loaded, depending on BIOS version and type, you can reset the defaults by using "F9" key to Load Defaults, the "Load defaults" button on screen, or the "Alt" + "F" key combination to load factory defaults.
  • Press "Esc" on your keyboard and select save and exit.
  • Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your system to restart for the BIOS settings to reset.
Aug 30, 2013 | Dell Inspiron Computers & Internet
I am running Windows XP Home edition. I changed some setting in the "Setup" using the F2 key, and then like an idiot changed something in the categories I think called "Bios"
There are several ways to reset your Bios. But until you are locked out of it, there is an easy solution. You need to reset your bios. The location and wording of this option varies for every different BIOS.It will typically be called "Reset to Default", "Factory Default", "Setup Defaults", or something similar. It may be located in one of the tabs or it may be an option listed near the navigation buttons.
What you need to do is reboot your PC, press F12 or DEL until the bios screen arrives. Then you need to just navigate to 'Defaults' or "Load Defaults" or "Load Reset to Defaults", select it, press yes and select "save and exit". The PC will restart and the BIOS should be reset to original setting.
Feb 03, 2013 | Dell Vostro 200 PC Desktop
Sony ericsson xperia 8 phone icon & box icon on home page disappeared. How do I restore?
1.Go to "Settings" from the iPhone home screen.
2. Select "General."
3. Go to "Reset" at the bottom of the page.
4. Click "Reset Home Screen Layout."
5. Click "Reset Home Screen." The icons on the home screen are now back to the default icons, including the App Store icon.
as well as you can restore all icon on home page.
Aug 17, 2012 | Sony Ericsson XPERIA X8 Cell Phone
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
The computer has to be reset. My options are to tow it to a dealer or have someone come to my home to rest it
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Jun 29, 2011 | Computers & Internet
How do i change my iphone from chinese settings?
Hey there,
You can reset your iphone back to default english by doing a "hard reset".
Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
You may let go when you see the silver Apple logo.
You have completed a hard reset successfully.
Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
Mar 25, 2011 | Apple iPhone 3G
Iphone not loading after reset, only apple sign is being desplayed
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.u try this
Apr 17, 2009 | Apple iPhone 3G
Samsung black jack cell phone
There should be layouts available (i.e. AT&T Default, Large Font, Windows Simple, Windows Default....etc.). It changes the way the icons are arranged on the home screen.
Jun 23, 2008 | Samsung BlackJack Smartphone
Exercise & Fitness Logo
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
