Question about Microwave Ovens
Honey left in and bottle melted and honey burned and honey is hardened on the base of the mocrowave
Please guys help me, every time i baked the cookies , its always burned :(
The oven temperature may be too high. Get an oven thermometer and set it in the center of your oven and check to see if the temperature on your oven matches it. Many ovens run 25 degrees or more off of the set temperature. My mother's oven used to need to be set at 325 if she wanted it to bake at 350.
If the cookies are black on the bottom, but doughy in the centers, this may also be a case where the oven temperature is too high.
Another problem may be that you are baking them too long. Cookie baking is a precise thing. It may seem duh-obvious, but be sure you use a timer, lol. If the recipe calls for 10 minutes, and they are always burned, start checking them at 8 minutes.
If you are substituting honey for the sugar in the recipe, remember to lower the oven temperature by 25 degrees and decrease the liquids by a small amount to compensate. Honey browns/burns much faster than sugar.
Hope these suggestions help. =)
Aug 25, 2013 | Amana Microwave Ovens
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
Don't wok at all not even the clock
well not a smart thing to do realy,,,,,it burns out the magnatron,,,,,trying to heat up a box of nothing?
you may well find its going to be a lot cheeper buying a new unit than trying to get yours fixed up,,
please dont go poking about inside this mocrowave it can still kill you as there is likley to be 1000 of volts still in it,,,they kill out right too, be warned,,,,,
Jun 05, 2010 | Maytag MMV4205 Microwave Oven
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
Sep 27, 2009 | LG LRM1250 Microwave Oven
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Microwave faulty
High voltage parts are suspect. You are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 09, 2008 | Microwave Ovens
Kenmore microwave mod. # 721.62463200 Fire
This sort of thing is caused by food particles burning and maybe the wave guide cover has a hole in it. They do not, if used correctly, burn as you describe.
May 19, 2017 | Microwave Ovens
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
