Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Where do you access the drain pump
Where do i access the pump
How do I access my drain pump if its clogged in a Frigidaire model fafw3577kno
Thank you for your post, zoorevvy!
I understand that you would like to access the drain pump on your Frigidaire washer, FAFW3577KN0. There are no instructions available on how to access the drain pump. If you are attempting to change it out this is not a simple DIY job. I would recommend having a professional technician come out to properly dismantle your washer to replace any electrical components. This will help to avoid any personal injury. Hope this is helpful. -Matt
Jan 27, 2015 | Frigidaire Washing Machines
I have a model 417 Kenmore front load washer which stopped running and shows a E 20 error message in the window. What does that mean and how can I get it operating again?
E20 error code means that the control does not see it draining water out.
When you start the washer, you should hear the drain pump running or at least making a humming noise.
A service technician would:
- Check the drain hose for restrictions
- Start the washer and listen for the drain pump operating.
- If the drain pump is not operating, a technician would then check the voltage supply to the drain motor.
The technician would remove the lower access panel by removing the screws located along the bottom of the panel to access the drain pump assembly.
If you take off your lower front access panel click this link and check item number "18": Parts_Diagram
You will see the pump inside the bottom of it, with the 2 black rubber hoses attached to it. Here is the pump sample: drain-pump-assembly Try to look this part with the correct model number of your device.
Hope this helps.
Aug 16, 2011 | Kenmore Washing Machines
Drum not spinning for final spin
Hi jssrfeb,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
My machine will not spin or go to the next cycle
Hi johnson_anit,
Kind Regards :-)
Jul 18, 2011 | KitchenAid Washing Machines
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
GET ERROR CODE f-2, AND IT WONT DRAIN THE WATER kENMORE ELITE hE3T
It is a code for a long drain problem (more than eight minutes). Press the Pause/Cancel button twice to clear the display. When the display is clear, press the Drain & Spin button then select No Spin by pressing the Spin Speed button, and then press and hold the Start button to start draining the water.
Use your senses to check whether the drain pump is running or not. The drain pump is located at the front right bottom of the machine. Check the volume of water being discharged to the drainage.
Disconnect power to the washer and check the drain hose for clogs and kinks, and then repeat the No Spin draining process, if the drain pump is running and water is being pumped out, until the water is completely drained out of the washer. Just press the Pause/Cancel button twice when the code appears to clear the display and restart draining.
Make sure the drain hose is raised no more than eight feet above the floor where the washer is installed. The drain pump cannot pump the water properly out to the drainage more than eight feet above the floor.
When draining is complete, empty the machine then prop up the bottom front edge of the washer to allow easy access to the three screws attaching the lower front access panel to the cabinet. Remove the screws, and then push the panel down and off the cabinet to access the drain pump.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter for any debris that might be causing the pump to work poorly then screw it back in place.
Slide the lower front access panel up back into the cabinet and secure it the three screws.
Mar 12, 2010 | Washing Machines
Maytag MAV4755AWW. Water remains in clothes after spin cycle.
Check the drain hose for kinks and clear it from any clogging. If no clogging or kink is found, drain the water manually.
Remove the rear access panel to access the drain pump. Press the hose clamps and move it away from the pump. Remove the hoses from the pump and drain the remaining water from the tub drain hose into a shallow pan.
Lay the machine on its side on a cushioned surface to allow easy access and removal of the drive belt.
Remove the three screws securing the drain pump to the base of the machine. Check the pump impeller for any damage and clear it from any debris that may be preventing it to pump the water out. Replace the drain pump (part #35-6780) if the impeller is damaged. Secure the new drain pump to the base of the machine with the three screws and reinstall the drive belt and the rear access panel.
Note: Disconnect the machine from the power outlet before servicing to avoid the hazard of electric shock.
Feb 22, 2010 | Maytag MAV4755A Top Load Washer
Stops at spin cycle does not drain.
Hi.
The first thing to check is the drain system. Check the drain hose at the back, and the drain pump. The drain pump can be tested advancing the cycle to drain. It can also be tested by a technician, energizing the pump directly.
The pump can be accessed removing the small service panel in front of the washer. Access to pump is located on lower right hand corner in front.
After removing the panel the pump is accessed and disconnected from hoses to remove the blockage in there. The procedure is also illustrated in service manual. Have a container ready to collect water if you DIY.
If the pump is OK other parts that can cause the problem, and that must be tested are the pressure switch, and the electronic control board.
Regards.
Oct 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
20 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
