Question about ION Block Rocker Explorer Sound System w/ Bluetooth
Microphone doesn't work
HOw do I use the microphone?
Philips SHG7980 microphone problem
Go to Tools...Options...Audio Settings and try choosing different choices for Microphone.
Jan 18, 2014 | Philips PC GAMING HEADSET BLACK/RED...
Sennheiser ew g2 bodypack with shure u2 receiver compatibility: When I tune the frequencies similar to each other, the U 2 gets an RF-Signal, but it doesn`t receive any audio-signal, when i talk into...
Sorry, that will not work. Typically, it is not possible to use one manufacturers transmitter with another manufacturers receiver. The two manufacturers use different tone-key squelch, different noise reduction, and different companding schemes.
Aug 09, 2013 | Shure U2 / 87 With SM-87 Professional...
Laptop Microphone- Hardware Problem?
Check the microphone opening for accumulated "crud"
Jul 13, 2013 | Toshiba Satellite Computers & Internet
Check the headphones for an on/off switch
Nov 15, 2012 | GE Universal All-in-One Stereo Headset...
My microphone used to work,now it doesn't.
Check the PC with an external microphone and if this works then the internal mic can be faulty and should be replaced.
Also open the audio settings and check the level of the microphone settings .
you can test and confirm the working of the microphone.
Aug 09, 2011 | Fujitsu LifeBook A1110 Notebook
GigaWARE USB microphone doesn't work with PC Windows 10. Why don't drivers come with the product?
the microphone might not need usb drivers to work
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Aug 04, 2011 | Computers & Internet
My microphone doesn't work, I can't hear any voice. Can you help me? That is R21S microphone
its probably a wire came loose, unscrew the head (airguard) then you should h ave 2 tiny screws that hold the switch in place, carefully slide it forward and as you do push the main cord for the amp plug in along with it as you push it through,, check those wires to be sure the connection hasn't come loose
Jun 12, 2011 | Samson R21S Microphone
ION Block Rocker Explorer Sound System w/ Bluetooth Logo
359 people viewed this question
Top ION Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an ION Baby Gear Expert? Answer questions, earn points and help others
