Question about Field N- Forest Winter Trail Snowshoes
Front leather toe strap location
Does leather go on top of the toe cord does the leather piece go on top of the toe cord
Have a new pair of newport h2 sandals that I love, but my pinky toe sticks through the straps on one foot. Any suggestions on what I can do?
I would put a piece of leather or rip-stop cloth on the inside between the straps where the toe sticks out. This would stop if from coming out.
May 27, 2014 | Keen Newport Sandals
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
How to change leather strap
You may follow this link on youtube which explains exactly how to change a leather strap: http://www.youtube.com/watch?v=TtPde-M5Xz0
Dec 25, 2012 | Guess Pink Leather Strap U10580L3 Watch...
How to Buy The Right Shoes for men?
I'll review number of shoe types for you guys! First - the wing tip;
For Work: Not all wing tips look right with suits. But this pair, with its closed-lace construction, slim leather soles, and rich brown patina, could hold its own with most any three-piece.
For the Weekend: A chunkier toe and a rugged sole are the stuff of casual wing tips and many an action-packed weekend. And if the leather picks up a scuff or two, so much the better.
Seconds, The Oxford:
For Work: You can't get much more formal than a finely wrought pair of black oxfords, especially when the toe looks like this: not too pointy, not too round, and not remotely square.
For the Weekend: The lighter the shade of brown and the softer the hand of the leather (or, in this case, suede), the better your oxfords will look with jeans, khaki chinos or beat-up cords.
And last type is the the Boot:
For Work: Opt for black (inherently more dressy than brown), and keep in mind, the finer the construction, the more polished they'll look. Speaking of: Keep them shiny.
For the Weekend: Look for something unstructured like desert boots (or another spongy-soled variation thereof). They're just the kind of lightweight knockabouts that downtime requires.
Oct 27, 2010 | Clothing Accessories
Replacing plastic strap that hold the toe cap.
You just need to remove the binding form the board and look underneath the binding. If it doesn't drop out by itself just lever the broken piece out with a flat head screw driver. Once this is done you can insert the new part screw on the cap strap
Mar 04, 2010 | Burton 07 Custom S Bindings Snowboard...
My airdyne has this warning sticker cautioning against using toe clips or straps. I wonder why? Also would it apply to SPD clips if I mounted them?
yea! i remember toeclips and straps and tightening them at 50kmh just before the sprint... bit dodgy. it's just that they really can become stuck as there is a beartrap system that locks on to the leather strap and they are outdated by the new spd's and cleat lock systems. You can of course use them but check the pedal width to make sure your knees are not pronated outward from the frame as all new systems have a narrower bottom bracket. The Spd's will be fine as will Candy's, i use both
Mar 04, 2010 | Zefal Bicycle Christophe Mountain Bike Toe...
Hi i need a replacement front toe strap for LQ 1500 LS3
Is this for the binding? you may be able to buy a toe-cap strap set from Burton or Ride (both sell sets for around 30.00) You will have to compare the mounting design of the toe ******** the burton/rides vs your binding
Feb 13, 2010 | Liquid Force Winter Sports
Gossip watches with changeable ribbon straps
good day,
hope this link below will solve your problem.
watches
Jun 24, 2009 | gossip Rectangle Case Leather Strap Watch
Plastic toes strap broke off, where to find a piece to replace it
Have you tried the local ski shop they should have them.. other wise if theyre burtons try contacting them directly and ask them. if theyre not try the manufacturer but i doubt that will do anything. Do you have a scheels around? I know they carry straps.
Jan 16, 2009 | Park Raiden Bindings 0 Snowboard Binding
Field N- Forest Winter Trail Snowshoes Logo
465 people viewed this question
Top Field N- Forest Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Field N- Forest Winter Sport Expert? Answer questions, earn points and help others
