Question about Sony BDV-N790W 3D Blu-ray 5.1-Channel Home Theater System
Sony bdv n790w dvd stuck
Won't read dvd and system is frozen while it tries. Will not eject dvd
welcomejee
  • 10594 Answers
SOURCE: sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Posted on Jan 03, 2009
  • 254 Answers
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Posted on Apr 03, 2009
pabloloco
  • 2335 Answers
SOURCE: SONY BDV-FS350 INSTRUCTION MANUAL
I found some support for a SONY BDV-360FS on their european site.
This is the closest model # I could find.
Is this the unit you are looking for support on?
Not the BDP-S300 or BDP-S350 blu-ray players, but a player with a builtin amplifier and speakers, is that right?
Posted on Oct 09, 2009
asnowman
  • 788 Answers
SOURCE: DVD stuck inside sony dav-sc5.
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Posted on Feb 08, 2010
mybradley7
  • 242 Answers
SOURCE: Sony SLV-D350P - VHS tape stuck, will not eject,
check the tip in my profile
Posted on Jul 17, 2010
Why is my Sony bdvn790 stuck on bd/DVD and the front light flashes
I am having the same issue. From what I can tell (at least in my case), there was a disc stuck in the DVD drive. I had to dismantle the chassis, remove the drive and manually "eject" the disc. There is a manual screw port under the BD/DVD drive that you turn and it will manually eject the disc. However, removing the disc from the drive did not solve my problem. I am still getting the BD/DVD displayed when powering the system back on and the light is flashing as you described.
Oct 12, 2014 | Sony Bdv-n790w 5.1-channel 1000w Blu-ray...
"RM OFF"
I am having the same problem - did you find a way to fix this???
May 11, 2014 | Sony BDV-N790W 3D Blu-ray Home Theater...
BDV-E580 Sony Entertainment system "Demo Lock"
try turning it on and putting it in dvd function. Then hold the stop and eject buttons for about 5 seconds. The display should read 'demo off' then you should be able to operate normally.
Feb 06, 2014 | Audio Players & Recorders
Stuck in demo mode / demo lock
Put the unit in dvd mode. then press and hold the stop and eject buttons. The display should read "demo off". Then the tray should operate normally.
May 28, 2013 | Sony BDV-E280 Home Theater System - 3.1 3D...
Sony BDV-E370
From page 68 of this manual: "Contact your Sony dealer or local authorized Sony service facility."
Mar 02, 2013 | Sony BDV-E370 Theater System
My home theatre unit bdv-L600 will not eject the DVD as it says it is locked
I think your best bet is to remove the top of the unit and see what has caused it to lock. Removing the CD once the top is off may fix your problem.
Nov 10, 2012 | Sony BDV-L600 3D Home Cinema System SONY1
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing...
    asnowman
    Feb 08, 2010 | Sony DAV-SC5 System
    Sony BDV-N790W 3D Blu-ray 5.1-Channel Home Theater System Logo
    101 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
