Question about HEALTHRIDER H70E Elliptical Resistance Motor Model Number HMEL507
Healthrider h70e, Motor, Resistance
No resistancess
No resistance for Healthrider H90E elliptical
More than likely your going to need a console...If you checked all the power from the console down to the resistance motor and that's good then console is bad.
Dec 08, 2013 | HEALTHRIDER H90E Elliptical Console Model...
Controller what is the voltages output on a healthrider s300i
the voltage controller is the same for input voltage terminal of the motor .
test the input voltage terminal motor, if there ARE not the motor is faulty.Read my personal TIPS motor
2) test the output voltage control board, if there ARE not the control board is faulty
God bless you
Oct 21, 2013 | HEALTHRIDER S300i Treadmill Motor Control...
My Healthrider Elliptical H70e is measuring km/hour instead of miles/hour. How did I change this setting and how can I change it back?
there 2 ways: 1) go to back the display board , are small orifice, use the point of erase pencisl. and click the small switch and change the km to miles or vice-versa
2) use the menu, and go to speed how to change the speed.
use your instr. manual if you do not have download free. www.fitness.manualsonline.com
God bless you
Jan 22, 2013 | Exercise & Fitness
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
HEALTHRIDER H70E Elliptical Resistance Motor Model Number HMEL507 Logo
Top HEALTHRIDER Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
