Question about Faberware FCP280 Coffee Maker
Need to replace heater coil FCP Model
I need to know how to remove the element and where to buy a replacement if there is one.
I have GE refrigerator model ZIS42CMC. How do I remove the evaportor coil from the evaportor compartment so that I can access the defrost heater?
you don't as to do that will loose all the gas and you will be in a bigger cost zone than having a technician fix it
Jul 10, 2017 | GE Refrigerators
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
Mar 18, 2015 | Element Water Heaters
Water heater elements for 2006 conquest trailer
Remove the old element. Take note of the water heater make and model, i.e. Suburban SW6DE or Atwood GC6AA. You can find the replacement at your local RV parts department. I have even seen them at Lowe's. Or you can buy one online.
Apr 19, 2014 | Gulf Stream RVs
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Water Heaters
Need to change the heater element
1) Unknown which product. Fixya truncates questions the expert receives.
2) Copy following link for replacing element on tank-type water heater.
3) Feb 2013. Add comment and describe exact product type, model, and brand name for possible location of product manual or resources.
4) Repost question and include brand name, model and type.
Attach a photo for better identification of problem, but fixya degrades image seriously and fine detail cannot be viewed by expert.
5) Repost question and include video that fixya may also truncate and downsize-degrade so it might be useless.
6) Post video on utube and send link.
Feb 04, 2013 | Water Heaters
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Dryer quit heating
Hello Friend, Your problem is very simple to fix. I'm assuming that you have a standsrd model Whilpool dryer. You didn't specify if you have a gas or electric model so I have given you the basic instruction to repair both models.
IF GAS DRYER FOLLOW THESE STEPS: You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed.
IF ELECTRIC DRYER FOLLOW THESE STEPS: Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new.
Happy to help, Tim.
Jun 27, 2009 | Whirlpool WGD5300S Dryer
Changing heating element
No need to buy the whole pan. The replacement coil is way less. 5300622032
Very easy dryer to repair. Start by popping the top and then removing the front. Get te drum out and remove the heater assembly. Remove the old coil. NOTE: when replacing the new coil be vewy vewy careful not to stretch the coil too much as this causes a hot spot and shortens the life of the coil considerably as in like one load maybe. LOL.
db4f97d.jpg.
Jan 31, 2009 | Frigidaire GLER642A Electric Dryer
Faberware FCP280 Coffee Maker Logo
20 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Dael Escher
Level 1 Expert
Kolbrun...
richie46
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
