Question about Plumbing
Danze fp1e5100cp leaking at base
My Danze showerhead runs even when turned off
try cleaning the inside of the valve with 1500 grit wet sandpaper. and then put a lot of waterproof plumbing grease in there and also on the cartridge. sometimes you can get a build up of hard water inside the valve body and that will cause leaks. just dont over do it with the sandpaper and dont anything more abrasive than 1500 grit.
Nov 26, 2012 | Danze D135300BT Single Handle 3/4 Volume...
Danze kitchen faucet no:FS1B4034NP. It leaks around the spout when i turn the water on. I have received a new spout seal kit but no instructions on how to install
you should be able to unscrew collar,the top piece just before it goes into base,I use a piece of cardboard in the jaws of channel lock pliers to keep from tearing up chrome
Jan 28, 2011 | Danze Plumbing
My Danze brass pop-up drain assembly w/lift rod and overflow leaks on the threads that lead upto the flange. I have tried a small amount of putty to a large amount and still leaks after about 1 week from...
I always use white silicone - putty always cracks and leaks. Silicone makes a sort of custom rubber gaskit and never leaks. Clean off with paper towels immediately before it skins over
Dec 21, 2010 | Danze 1-1/4 '' Brass Pop-up Drain Assembly...
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
Water leaking around base
Make sure aerator is tight and check cartridge under the handle
Oct 29, 2009 | Danze & Antioch™ Single Handle...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
26 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
