Question about Rusk RSK732 Professional Str8 Titanium-Infused Ceramic Flat Iron 1-1/4 Inch 1-1/4"
Power supply swivel
Has to be swiveled in a certain position in order to keep power
How can I find the "Polyester" setting?
Just put it on the lowest setting that is near to the off position. Polyester can melt on a high heat setting.
Aug 13, 2014 | Shark GI500 Versatile 1400 Watt Steam Iron...
I have two irons. one if them won't turn on anymore and i noticed the light kept fading out. the light on the other one flickers and it stops working halfway through straightening. any solutions?
Most likely it is the power cord. We have the same iron and the power cord has a break in it just as it comes out of the swivel. You can turn it on and hold the power cord tight up against the swivel and it should stay on. I was able to fix it by stripping the cord down to the wire soldering and adding shrink tubing to the connection. That lasted for about 1 year and it has done it again. I may have to replace it but not sure how to take it apart.
Sep 19, 2010 | Conair Infiniti Instant Heat Ceramic Hair...
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Iron will not go on until you wiggle cord &ball
Rowenta DZ 9050 steam iron must be sent to Rowentas repair service in your area.
Local Fix shops will not work on them.
They have parts only.
Feb 19, 2009 | Rowenta Irons
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Power won't come on
You have a short in the cord. If you knew where the short was, you could possibly repair it. However, I would strongly suggest buying a new iron. An iron is an appliance that can burn your house down even when it's in GOOD working order. You should be able to buy a decent iron for around $30, and I would say the peace of mind alone would be worth it. Hope this helps,
Chad
Oct 08, 2008 | Rowenta Professional DE880 Iron
Rusk RSK732 Professional Str8 Titanium-Infused Ceramic Flat Iron 1-1/4 Inch 1-1/4" Logo
29 people viewed this question
Top Rusk Irons Experts
Are you a Rusk Iron Expert? Answer questions, earn points and help others
