The video format not supported
Have radio signals but no tv picture, just no picture
French secam-L
You can get software that will capture the video and convert it. It will also make the DVD for you. If the video you have picks up the signal then so should the capture software. They have options to set the capture signal to the French system so that shouldn't be a problem. You however will need a computer that can cope with the video signals. Otherwise it will record it but the picture will jump as the signals drop.
There are some cheap software on the market for doing these, such as Sony Movie Studio, Magix Movie Editor and one made by Serif.
Jul 23, 2013 | Televison & Video
When i have my ps3 hooked up by hdmi... it will shut off and say invalid format. what does this mean????
It means the video resolution signal from your PS3 is too high for the TV to display, please see the TV spec as to what the highest resolution it can support, or you can change the video resolution of the PS3 starting at the lowest resolution and keep going up from there until the TV will not display any more.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Aug 26, 2011 | LG Televison & Video
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I have question, can I have a PC display on TV through VGA cable only I mean by three (Green Signal, Red Signal and Blue Signal) PINs of VGA cable?
Yes you can, but you will need a sync box for the computer signal to be formatted to the correct signal for a tv.
Mar 23, 2011 | Samsung 793S 17" CRT Monitor
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
MPN MAX685BT
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at http://wize.com/car-dvd-players/p469604-clarion-max685bt
Good luck.
Hope this helps!
Jan 21, 2011 | Clarion MAX685BT Car DVD Player
I own a Norcent TV model LT-1931. I am a DirectTV
Out of range = the tv receives a signal with a resolution higher than it can display. Connect your DirectTV to another tv and make sure that the signal is one supported by your tv (any SD format will do). If it is then connect your tv to a pc and test the supported resolutions - if none work or the image is bad then the storm has fried its image processor - a repairman should take a look at it.
Jul 29, 2010 | Norcent Technologies2703 27" TV
Am unable to get the ion converter to detect a video signal
I would like to share you a best converter i have used:
Video Download Studio
Click here to see the full reviews and have a free trial:
http://www.downloadvideos-convert.com/download-videos-music
It can convert almost any the video format to another with high output quality.
This full-featured video converter software also can help you:
1.convert between all mainstream video and audio formats,such as(mp4, mov, m4v, vob, XviD, avi, flv, 3gp, 3g2, mpg,wmv,etc;m4v, mp3, wav, ac3,etc)
2.extract audio tracks from video files to other audio formats
3.support all popular portable multimedia players
4.edit video-Merge, Trim, Crop and Snapshot
It is very easy to use,just follow the instructions on it you can convert your videos and make your movies and music taken easily on PSP, PS3, iPod, iPhone, Apple TV, Xbox or other digital devices.
Hope this can help you.
Jan 23, 2010 | ION Audio VCR 2 PC USB VHS Video to...
In Video Studio Pro I can not save downloaded TV signal, nect time I open the Movie Wizard to record TV signal I have to scan all channels again and I can not save the TV signal, signal is cable from...
Jul 27, 2009 | Corel Video Studio Pro X2 for PC
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
