Question about Walgreens Cool Mist Humidifier Humidifier
Leaks model #2055 leaks from bottom of unit
Water leaking from bottom of 550 aprilair humidifer
Hi they should be a hose going to a drain in the floor there are insrtuctions on the wed just google the make and model and you can down load them
Dec 28, 2009 | Aprilaire 550 Humidifier
Leaking out of the bottom of the unit on to the
Check the drain to make sure its clear and that the tray is properly aligned with the drain of the housing. Also check how much water is being fed to the unit sometimes you have too much and it is blown off the pad. Just a personal opinion I have never installed a humidifier on the front of a furnace for this reason. I hope this helps
Tinner
Sunsetmech
Dec 10, 2009 | Aprilaire Humidifiers
The spring fell out of the cap and now water leaks out. Can you get a replacement tank cap?
go to kaz.com and search using your model # (found on the bottom of the unit usually). i had to do this a few months ago.
Oct 18, 2009 | Vicks V3100 1.2 Gallon Humidifier
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
My 7142 leaks
There are a few hose connections inside the unit related to the heater element. Water flows from the reservoir down into the unit, takes a turn into a tube with the heater element wrapped around it, then turns back up into the mister area. Any of the four connections (base to first elbow, elbow to heater tube, heater tube to second elbow or second elbow to base) could be leaking.
The white ring around the mister disk cracked on my unit, letting water leak out the bottom as you describe... Take a close look at that.
It's also possible the base itself is cracked somewhere... Look closely at the mister and reservoir areas of the base for cracks.
Dec 16, 2008 | Air-O-Swiss U7142 Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Walgreens Cool Mist Humidifier Humidifier Logo
Top Walgreens Humidifiers Experts
Dennis
Rich Brown
Tom Chichester
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
