Question about Whirlpool LER4634J Electric Dryer
My dryer Model # LER4634eq0 is not operating sometimes. It started out squeaking. Now, it will turn on and continue for about 15 minutes, then shut off. The squeaking has stopped, but you can hear the motor sounds like it's working really hard. It will shut off after 15 minutes, then after it cools down (my opinion) it will start up, but only for about 15 minutes.
  • julie_kistle Jun 14, 2009
    Thank you for the prompt response.
    Brigadier General:
  • 8,619 Answers
Hi
You'll need to check the rear drum roller (part #44) --
Whirlpool LER4634eq rear drum roller (part #44)
and idler pulley (part #53) --
Whirlpool LER4634eq idler pulley (part #53)
which are making squeaking noises while your dryer is running. These dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they become noisy. You should replace the whole set of rollers at the same time. Also the Idler pulley needs to be checked as the pulley keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
It is definetly idler pulley or the rollers however, if these things are fine then you'll need to check blower wheel (part #10). You can check this by looking at the following figure--
Whirlpool LER4634eq blower wheel (part #10)
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 14, 2009
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
Sometimes my dryer will shut off 5 min after I start it then when I try to turn on again notheing I have to wait for a minute then it will let me turn on. Then sometimes it will shut off maybe 15 or 20...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 30, 2010 | Crosley Dryers
Maytag Gas Dryer, Performer G2300 Dryer starting making loud squeaking noises and then after about 2 dryer loads of this noise, the dryer just shut off midcycle. When I tried to restart the dryer, it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 07, 2010 | Dryers
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Dryer continues to shut of on it's own
check to see if theres an exhaust sensor it may be that,
Nov 21, 2007 | Fisher and Paykel DE06 Electric Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LER4634J Electric Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
