Question about KitchenAid 32685 Mixer
Kitchenaid Motor won't run
Motor will not run
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
My kitchen aid K5SS won't run
first check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Dec 05, 2012 | KitchenAid K5SS Heavy Duty Commercial...
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
My machine simply won't turn on .
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
Won't turn on
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid stand mixer KSM50PWH. Was kneading dough with dough hook attachment and it quit turning. Motor works fine but the part that's supposed to go round and round doesn't. Can I fix this?
The Nylon Worm Gear has stripped. This is designed into the part so if the Mixer gets overloaded, it won't burn out the motor. Which is odd if you have the reset switch like I do.
Part# 4162897
You can buy it online at Kitchenaid.com
Jan 17, 2011 | KitchenAid Food Mixers
KitchenAid 325 Heavy Duty Stand Mixer runs with low power & clicking noise
well there is a couple of things to try
1. see if kitchenaid sells the motor or
2. if a local appliance parts store can get the motor
this is the only thing you can do about the motor , the wires in the motor are shot and it will need reconstructing in the wireing, that is why it won't run fast and strong , because the wires have been heated up to much and now they can't create a strong enough magnetic field
but to replace the motor shouldn't be to hard just a little patience
if you need any more help just let me know!
electech
Oct 22, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid 32685 Mixer Logo
277 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
