Question about Saitek Pro Flight Yoke System Flight Simulator
Saitek Throttle Quadrant wont go idle and full power
The throttle's first two axes (X and Y) seem to work between like 15%-85% range on FS2004. When I go to the calibration, everything seems OK, I get both 0 and 100 numbers, like I should.
thanks in advance.
  • kcancetin Jun 23, 2009
    Exactly Gary! Thanks a lot.
    This should go in the manual.
I had a similiar problem and after spending hours researching and looking at forums I figured out the a solution. Plug in the quadrant directly into your computer and then configure it. At that time make your necessary tweaks, i.e. null zones and sensitivity adjustments. After you get it to work properly there, then you should plug it into your yoke and everything should work fine.
Best regards,
Gary
Posted on Jun 21, 2009
Error codes 2101 and 1516 on my 2004 chevy trailblazer
DTC P2101-
The commanded throttle position (TP), based on accelerator pedal position (APP) and possibly other limiting factors, is compared to the actual TP. The 2 values should be within a calibrated range of each other. Both the powertrain control module (PCM) and the throttle actuator control (TAC) module redundantly monitor the commanded and actual TP. This DTC sets if the PCM detects an out-of-range condition between commanded and actual throttle position.
DTC P1516
The predicted throttle position (TP) is compared to the actual throttle position. The two values should be within a calibrated range of each other. Both the powertrain control module (PCM) and the throttle actuator control (TAC) module redundantly monitor the predicted and actual throttle position. This DTC sets if the PCM detects an out of range condition between the predicted and actual throttle position.
Do you know what electronic throttle control is ?
Pt 1 2007 Chevy 2500HD Reduced Engine Power Warning Fault Code P1516...
Jul 31, 2017 | Cars & Trucks
Blocked lines
occasionally on the 1x0 range there is a valve stem issue that cause air to be allowed into the ink tube system and aslo for the ink to start crystalizing causing blockage , unfortunatly the fix includes a full set of ink tubes and possibly new printheads to complete the calibration
Nov 20, 2013 | HP DesignJet 110 Plus NR InkJet Printer
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
Worn out to fast at the top end of the throttle,can it be repaired,have already changed 2 over,replacement part or repair , many thanks js SAITEK THROTTLE QUANTRANT
Unfortunately Saitek does not have a repair service therefore no spare parts are available at all.
If your Throttle Quadrant was bought less then 2 years ago you should be able to get a replacement for it from your retailer or from Saitek.
Hope it helps...
Apr 07, 2011 | Saitek Pro Flight Throttle Quandrant...
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
The plate warmer will not work tonight. Everything else seems OK. I've tried turning the appliance off at the mains and then back on again, but it didn't work
Hi
I have just had the same problem, the connections just fall off the heater! Waiting for a response from Rangemaster....
cloudbase50
Dec 02, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Speed doesn't work
The markings on the TQ are not to be used literally. I suggest you use it to get the speed you want on your gauge and ignore markings on the TQ iteslf. Try re-calibrating in your sim program so it knows what the full range of the throttle is.
Apr 26, 2010 | Saitek Pro Flight Yoke System Flight...
My ds lite calibration seems to be off .when i start a game the touchscreen cursor wont move from right of screen but will move up and down .when i calibrate, it does hit the individual boxes. any help plz
The touch screen membrane is made up of two layers one controls the left to right axes and the other the up and down axes with the small ribbon cable in the middle, i cant remember of hand which is which now but you get the gist, there is a fine track going around the surrounds which keep the two together and it somtimes comes slightly unstuck, a quick tip is to run the stylus around the screen applying a bit of pressure somtimes this helps to make the screen more responsive, give it a try and then recalabrate it if you still have the same problem try taking the battery out and reseting the ds and calabrate it. Worst case the touch screen may need replaceing. i hope this helps.
Jan 18, 2010 | Nintendo DS Console
Saitek Pro Flight Yoke System Flight Simulator Logo
2,806 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
