Question about Verbatim Keyboard, Mouse, Keyboard and Mouse
Model 98111 uppercase number keys not functioning properly
When using with my imac the keys are typing incorrect symbols, ie. _ comes when hitting question mark, ^ comes when typing and symbol.
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
Apr 21, 2013 | Computers & Internet
MY KEYBOARD IS LOCKED IN UPPERCASE
Click on below image and try this after holding down the fn key.
Jul 25, 2012 | Fujitsu Siemens Computers & Internet
Function key for Rupee symbol in lenovo keyboard?
Maybe you have to Press and Hold the FN function key at the lower left portion of the keyboard then hit key 4 to get the rupee. Or it might be Press and Hold the ALT or CTRL key then hit key 4 to get it.
The key to know which key to Press and Hold is notice the color of the rupee symbol on key 4, then Press and Hold either the FN function key, Alt key or Ctrl that is the same color as the rupee.
May 07, 2012 | Lenovo ThinkCentre Computers & Internet
Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Apr 20, 2010 | Brother SX-4000 Typewriter
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Most of the keys work but when i hit "p" it comes up /p; and "h" comes up 6h
Do you have a (FN) key "also known as the Function Key" on your keyboard?
Many times you will have Numbers and Letters on the same keys.
If you have accidentally hit the FN key to turn it on you will be typing number/symbols instead of letters.
Aug 04, 2009 | Toshiba Satellite U305-S5097 Notebook
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
2nd shift key on logitech keyboard (corded) no longer works
YOU HAVE TO GO INTO KEYBOARD AND FIND THE SETTINGS FOR KEYS IN CONTROL PANNEL . SET IT AS ENGLISH.
Feb 25, 2009 | Logitech Cordless Desktop EX110
Verbatim  Keyboard, Mouse, Keyboard and Mouse Logo
24 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
