Question about RCA RCR311B Remote Control
I do not have my paper work anymore so i went online and got my code but i do not remember which buttons and what order to push them. can you please help.the remote is a rcr312w
  • 986 Answers
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time until the on/ff button remains lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
To Enter Code
Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). 2. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited. 3.While holding down the component key, enter the four-digit code While you are pressing the numbers, the illuminated ON•OFF key turns off. 4.After the fourth number is entered,the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Posted on Jun 14, 2009
My Samsung remote is BN59-01134B. I cannot remember how to program it to my TV I don't remember the code to program it to my TV I'm totally lost please help
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Dec 20, 2015 | Samsung Televison & Video
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  4. Turn on TV
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
6 cd player ford escape 2007 unlock
make a diagnostic and the web http://www.spobd2.comcan help you
May 21, 2013 | Cars & Trucks
Is there anyone who can help with this?
just follow the set of procedures HP recommends for clearing a paper jam, and it should work again. They have some documentation and videos online, here is one of them
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&lc=en&cc=us&dlc=en&product=441125
Jul 31, 2012 | HP Office Equipment & Supplies
I need instructions for a jumbo universal remote
im going to tell you automatic searching to operate your tv.... turn the tv on..
push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
Nov 15, 2008 | Universal Remote Control Remote Control
Code
Put in the same number 3 times (example 1111) until it locks and then push in the mute bottom and hold it and while you hold the mute button with your other finger push in the volume control (power button) and hold both of them until a new screen comes up and then put in 122164 and hit OK and that should work.
Oct 23, 2008 | Dual XDVD8181 Car Video Player
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
Master security code
please help me...i have a nokia 1112 and i forgot the security code. i try t use a mastercide generator but it does't work.my IM is:359736006161810....pls help me:((
Jan 19, 2008 | Nokia 1112 Cellular Phone
GE RM24948 Code input prob
1. Ch (-) x #
2. Vol (-) x #
3. Ch (+) x #
4. Vol (+) x #
Hope that helps. Same thing happened with me and it took a while to figure it out. like 20 min. to try all combinations with all different codes.
Oct 09, 2007 | GE RM24948 Remote Control
RCA RCR311B Remote Control Logo
412 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
