Question about Frigidaire GLEQ2152ES Electric Dryer
Litte or no heat
Not drying fast
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Painted 4 days ago & paint still not dry
Modern auto paints such as urethanes, acrylic enamels and others need catalysts or hardeners added, usually 1/2 to 1 pint per gallon. Call your local auto paint supplier and tell them what brand you used. Heat always helps drying time speed up. Retarders can be used as well as fast dry thinners depending on your local conditions. Vintage alkyd enamels needed heat or a full hot day to dry and stayed sensitive for weeks.
Jan 21, 2014 | 1994 Buick Park Avenue
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Printer will not print,only a litte yellow on the allignment set-up
have you checked your ink levels? even when you buy it new sometimes the ink can be dried out.
Feb 14, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
1999 ford expedition I am getting almost no heat in front or back. I have flushed out heatercore. I have change thermostat. When the engine is at 2.5 to 3,000 RPMs I get heat. No heat when it is idling....
Try the heater controles.There is a possibilaty with this expedition that the heater doors are not opening properly.When motor is at low RPM the vacum the motor pulls is low to.This vacum is what controls the doors and vent.You can pull vacum lines on and off ONE at a time and listen for the doors to open.There is also a good possibilaty the vent door contol switch at the dash could be bad.You would need a vacum gauge to test it though.
Dec 15, 2010 | 1999 Ford Expedition
Some games wont hold there saves
clean the litte gold tabs on the back of the game with alcohol and a q tip then dry it with another q tip
Oct 15, 2009 | Nintendo DS Console
Brand new samsung dryer not drying fast enough took 2hours to dry and still damp. the dryer was on more dry, high heat,
try checking your vent exhaust
and vent tube
soometimes airflow is slowed by clogs and build up causing long dry times
Oct 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Wont turn on
Make sure the battery is seed properly. Also, sometimes removing the battery and cleaning the connections helps. Try this---remove battery take a qtip put a tiny bit of rubbing alcohol on the end of it (DO NOT SOAK IT!!!!!) clean the connections. Let dry for a few minutes, reinstall the battery.
I had a phone that kept turning off on it's own and that worked.
Again, DO NOT SOAK THE QTIP, JUST A LITTE MOIST, DO NOT USE WATER!!!!!!!
I CAN'T BE RESPONSIBLE IF YOU DO IT WRONG.
RUBBING ALCOHOL DRIES FAST
Mar 27, 2008 | LG VX9800 Cellular Phone
Clothes aren't getting dry very fast
First, check your circuit breakers, turn them off and on...there are two linked together labeled 40 amperes or more. Next guess will be the thermostat or the heating coils. Use a multimeter to check these parts. A diagram is usually attached to the back of the unit. Oh, is the drum turning? Are your clothes reasonably damp dry when you put them in? Is the vent hose kinked when the unit is in place?
Dec 16, 2007 | Whirlpool LEQ8858J Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
13 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
