Question about Sylvania 6427TE 27" TV
Screen not full size, cut off at bottom.
Screen size small at startup
Why can't I enlarge Netflix movie on computer screen
Hi Linda,
What browser are you using? Typically, when viewing a Netflix title, there should be a little full screen button on the bottom right corner that you can click on to take it full screen.
I've included the troubleshooting guide from Netflix below for full screen issues:
Netflix full screen is not working on my computer
Hope this helps!
Feb 28, 2015 | HP Computers & Internet
My screen on my television does show the full screen
use the 'format' button or 'size' button on your remote to switch between the different viewing modes. Keep in mind that if the show being broadcast isn't in a widescreen format you will either be stretching the image on screen sideways to fill, or you will be cutting off the top and bottom edges in order to fill the screen without any image distortion.
Sep 22, 2014 | Panasonic VIERA Televison & Video
My screen picture used to be the full size of the secreen, now there is a border on the top and bottom cutting the picture down like in the movie theatres. How do you get rid of the border and get back...
If you are using cable TV there a button on the remote "*" which zoom in and out. You can also check with your cable company in case you have HD TV and not using a HD box.
Jun 20, 2014 | LG 50" 5700 Series LED HDTV - 50LN5700
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I have changed the screen size to 16 x 9. There is black space at the top and bottom of the screen. What do I do to correct this?
Hi welcome to Fixya,
Presently there are 16 formats (sizes) transmitted and you may need to hit a button to show a full screen sometimes on some channels. The format , aspect or size buttons are on both the TV remote and any cable / dish remote you have . set the TV to full or 16x9 if using a cable / dish box, then set the box to the stretch mode and the picture should be full, there may also be a zoom setting that will fill the picture but may cut off the edges.
Respond with more details or try the suggested settings
Thanks
Roety
Aug 03, 2010 | Panasonic Televison & Video
Bottom of screen cut off
This is a limitation because of the screen size of the Aspire One. Unfortunately, no fix for that...Sorry
Mar 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
VIZIO GV4VL cuts off the bottom of screen
on the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Jan 21, 2009 | Vizio GV42L 42 in. LCD Television
Window sizes in ym
It's about windows of yahoo messanger and how to manage them. note my friends cam can go full screen and then press esc to reduce it but the buttons top left of window are not clear enough so instead of making full screen i usully close it down by mistake....is there a keyboard short cut to make it bigger.
Dec 21, 2008 | Heating & Cooling
Sans e250 photo size
Do the fit screen option on the mp3 player. you are on the full screen mode, which for larger pictures cut them off.
Apr 14, 2008 | SanDisk Sansa e250 MP3 Player
Sylvania 6427TE 27" TV Logo
21 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
