Question about Uncle Milton Star Theater Pro
Blown out bulb
How do I fix a blown out bulb
  • MacKay Doran
    MacKay Doran Mar 26, 2014
    I have a blown out bulb on a Uncle Milton Star Theatre Pro. How do I change it?
Why is the center brake light not working?
Blown bulbs,blown fuse, broken wire
May 02, 2015 | 1993 Honda Accord
My right headlight is much brighter than my left someone said I have it on full beam but been told it may just need an adjustment how do I do this?
if it is a h4 headlight it could be that the wires are mixed up, it could be that while on high beam they are fine but when on low beam that the low beam part of the bulb has blown and tour left headlight is just being lit by a sidelight bulb, best off just to get two new headlight bulbs fitted first as it could just be a blown bulb and the cheapest fix is the best!
Nov 12, 2014 | Cars & Trucks
Kawasaki KLE 500 Headlight bulbs is blown each time the bike is started. Please help!
some where from the headlight to the switch there is a shorted wire ,,twelve volts wont just blow a bulb or fuse .
May 27, 2013 | Motorcycles
No left blinker
bad buib try switching left to right if it works if it works your bulb is bad if not you might have a bad bulb socket or bad power wire !!!! either way a easy fix
Feb 16, 2011 | 1989 Chevrolet K1500
I have a 56 hd-56g787 and it poped the other day, I instantly unplugged ,pulled the sid cocer off and now have a blown bulb.Will changing bulb fix my prob ?
Yes,if the bulb it ur only problems.Change the bulb.Tries websites like Partstore.com,Ebay.com to buy a new bulb.
Aug 30, 2010 | JVC HD-56G787 Television
Quit and won't come on again
On the lower right side on the back there is an access panel for bulb replacement I think it is four screws. Remove to check and see if bulb is blown, the tv runsa a self check and if the bulb is blown it will seem to be not working at all. I have the same unit and it fixed mine. You can find replacement bulbs online and i suggest a longer life one. RCA will charge you about $500.00 for a bulb you can get online for $200.00
Oct 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony cybershot dsc-h1 flash bulb has blown
You need to have it fixed at a service center.
Aug 13, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
The turn signals do not work on 2000 nissan exterra.Fuse was blown. Replaced and blew again after a few seconds.
1.Remove front & Rear turn signal Bulbs.
2.Replace Fuse.
3.Signal on.
4.Fix rear Signal Bulb.
5.Fix Front Signal Bulb.
7.If your Fuse blown.
8.Defect is There.
Jun 11, 2009 | 2000 Nissan Xterra
Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
May 25, 2009 | Microwave Ovens
Uncle Milton Star Theater Pro Logo
49 people viewed this question
Top Uncle Milton Toys Experts
Jim Goldsmith
Jim Goldsmith
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you an Uncle Milton Toy Expert? Answer questions, earn points and help others
