Question about Pride Celebrity X 4-Wheel Electric Scooter
Goes bit then stops press reset goes again then stops
Goes and stops have to press reset
  • Pride Master
  • 10,291 Answers
The motors are drawing too much current. Check how worn the brushes on the motor first, then download the service manual from Pride's website for more troubleshooting information.
Posted on Feb 24, 2015
How do I program a curves tech watch, sold by avon. Four options start, reset, mode, light...
There are four buttons - Mode, Light, Start and Reset.
Press the Mode button once and it enters a day setting mode. Press Mode again and it goes into an alarm set mode. Press Mode again and it goes into a time display mode with the seconds flashing. Press reset to toggle through seconds to minutes to hour to day. Press the start button to increase a value. Press Mode again to resume normal functions.
Mar 21, 2015 | Hardware & Accessories
Fuel gauge goes down at stop but rises again when accelerating.
Needle should move a little bit upon stop/go.If it is a lot would have to say it is the potentiometer in the sending unit fuel pump.
Jan 05, 2014 | 2008 Chevrolet Chevrolet Malibu Classic LS
Reset change engine oil light
Information taken from: http://www.idavette.net/tech/oilreset.htm
[quote]
The "Change Oil" indicator is reset by using a sequence of Driver Information Center (DIC) key presses as follows:
1. Turn ignition "ON", but do not start engine. (ALDL pin "G" should NOT be grounded.)
2. Press the "ENG/MET" button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of Step 2, press and hold the "GAUGES" button. While the button is held, the "Change Oil" indicator will flash.
4. Continue holding the "GAUGES" button until the "Change Oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds.
If it does not successfully reset, turn ignition "OFF" and repeat the procedure from Step 1.
[/quote]
Nov 16, 2009 | 1991 Chevrolet Corvette
Brake slippage
It sounds like a wheel sensor is failing, this will trip the ABS and cause the brakes to feel a bit weird. You will need to press the brake harder to stop if the ABS getts tripped.
Nov 13, 2009 | 2001 Isuzu Rodeo
When driving my gas pedal goes out. If I press
throttle position sensor most likely...
Oct 03, 2009 | 1997 GMC Sierra
Manufacturerscar alarm
My alarm is triggered when I leave the windows down a bit. There's a motion sensor for the interior of the car (I think it's thermal), so when a breeze blows cool outside air through the car's hot interior, it triggers. The interior sensor can be turned off by pressing the button just behind the driver's door and in front of the rear door. Try turning that off and see if it makes a difference. Post a comment with the results.
Jul 01, 2008 | 1999 Audi A4
Controller still wont work
Hmm. I think i'll need a bit more info please.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
Let me know how it goes.
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Pride Celebrity X 4-Wheel Electric Scooter  Logo
108 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
