Question about Philips Lands Phones
Power supply voltage cd150
Cd 150
1988 ford f 150 suddenly no power to fuel pumps
Hi Don,
your fuel pump is supplied voltage from the fuel pump relay which is supplied voltage from the EEC power relay ( fuel pump relay-Green Base, EEC power relay has a Brown Base) usually located on the left side(drivers side) of the engine compartment. These relays are supplied voltage from the fuse links at the starter solenoid on the firewall near the Battery, I hope this Helps Don!
Dight
Sep 29, 2013 | 1998 Ford F150 Regular Cab
I have Phillips CD150 handset. I am getting message as INITIAL, but the phone is not working. I have reconnected all the wirings again but still it is not working. Thanks in advance for sending me...
there is a problem with the Base unit (Charger), repair man said that the main IC should b changed which is too costy, better to buy another set.
The handset of the faulty unit can be paired with the new set.
in short the handset shows what it receives from the base (charger) so it has no fault and may be used with another set
Jun 16, 2011 | Philips CD-150
The handset reads "Initial". Everything
The problem is with the base unit (charger) u can use the handset with another unit
Nov 30, 2010 | Philips CD-150
Mijn nieuw gekochte CD150 telefoon blijft 'hands aanmld' aangeven sinds ik heb geprobeerd een 2e toestel aan te sluiten. Ook resetten lukt niet
Philips CD150 of CD 150 telefoons. Probleem als je 'Hands Aanmld' op t display houdt
Neem aan dat je er inmiddels uit bent. Had vanmiddag t probleem ook. Ging zover dat ik de telefoon wilde openschroeven om te kijken of ik ergens een knoopcelletje (batterijtje) even kon wegnemen en terugplaatsen. Is niet nodig. Oplossing is eenvoudig, maar je moet even uitproberen.
Druk 5 sec op de knop op t basisstation (de houder). Neem één vd telefoons, druk op menu en ga naar advanced instellingen, selecteer registering en toets daarna de pincode (0000) in. Minuutje wachten. Daarna zelfde procedure voor de andere handsets.
Succes ermee!
Ed van Rijckevorsel
Dec 07, 2008 | Lands Phones
FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
Oct 04, 2008 | Lite On (PA41519B1) 150-Watt Power Supply
Lands Phones Logo
79 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
