Question about Access Hd Access Hd 1080d Ntiaapproved Digitaltoanalog Tv Converter
One For All TV SIMPLE urc 6419 a tv daewoo
Configuracion One For All TV SIMPLE urc 6419 a tv daewoo
I NEED CODES FOR A DAEWOO TV USING THE URC 3300 PLEASE ASAP
0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058
Oct 10, 2012 | One For All URC-3300 Remote Control
Need daewoo tv code for urc-6131
The Daewoo TV codes for the URC-6131 are 0451, 0019, 0039, 0092, and 0623 . The manual for the URC-6131 is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/URC6131.pdf .
Please note that most universal remotes only have codes for TVs that were released 6 months or more before the remote was programmed. If your TV is newer than the URC-6131, you may need a new universal remote. (The URC-6131 manual has a copyright date of 2003. This version of the manual was scanned in February 2003.)
I hope this helps.
Jul 11, 2012 | One For All URC-6131 Remote Control
Code for deawoo tv
hi,
Setup code for daewoo Tv with URC-3021 are,
0451, 1661, 0092, 0672, 0623
ok
Jul 29, 2011 | One For All URC-3021 Remote Control
Sequence to program one for all remote
I can help you with your URC-3021 Universal Remote Control.
The codes for Daewoo TVs are: 0451, 1661, 0092, 0672, & 0623.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 05, 2010 | One For All URC-3021 Remote Control
Hi i need codes for matsui urc 11 remote to work bush tv thanks
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 15, 2010 | Daewoo DTQ-19P2FC 19" TV
Need a code for a daytek tv to program a rca universal remote
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Daytek TVs in the Urc-3021 Code List.
Please try the codes for Daewoo TVs.
The codes for Daewoo TV's are: 0451, 1661, 0092, 0672, & 0623.
If these don't work, don't give up; many manufacturer's re-use other's control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
Mar 07, 2010 | One For All URC-3021 Remote Control
I have a all for one remote. urc3220 . need code for i can change channel on a daewoo tv
I can help you with your URC-3220 Universal Remote Control issues.
The URC-3220 codes for Daewoo TV's are: 0451, 0019, 0092, & 0623.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Oct 31, 2009 | Daewoo DTQ-19P2FC 19" TV
Hi, I need the codes for connecting the One For All Big Easy URC-4330B03 to a Daewoo TV. Can you help?
Daewoo TV codes for a URC-4330 are:
If these don't work for your model, you'll need to run through the auto code search function.
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
Oct 13, 2009 | One For All URC-4330 Remote Control
Access Hd Access Hd 1080d Ntiaapproved Digitaltoanalog Tv Converter Logo
91 people viewed this question
Top Access Hd Televison & Video Experts
Electro Med Services...
Are you an Access Hd Televison and Video Expert? Answer questions, earn points and help others
