How to set a channel using manual tuning options in bpl old model CRT flat television
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
SOURCE: How to increase channels on Old BPL TV
hello sir, iam having a BPL tv,with 100 channels,,,the problem is i cnt watch around 50 channels,even the cable operator provides 100 +. there are three bands coming while tuning,L,H and U.am getting channel during L,H,but when it goes to U,then everything is blank...U(UHF) is starting from around 55,so all channels are blank upto 99. could you please help me???
Posted on Apr 27, 2010
Demonic-2011
  • 508 Answers
SOURCE: How to tune an old Television
The TV described is a VHF rotary tuner type, which will not work with any VCR manufactured after 1994 (those VCRs are UHF channel 37 output for Australia and 38 for NZ). VCRs were not as common in the 70s (as they were in the 80s onwards), and the K9 would have required a line-sync modification (involving 2 links added to U330 (the Line Control module) to use such a device anyway. The receiving channel for low-frequency VCRs such as 80s models, on this TV was either 0 or 1 (in Australia - channel 3 or 4 for NZ).
Philips did make a few variations of this chassis, including a later model, which was a push button VHF/UHF tuner type, but still a K9. Again, these were unreliable with any VCR connected, and they all required the line-sync modification.
It is extremely rare these days to find a working K9, as nearly all of them have 'popped their picture tubes' due to their age and the weight of the deflection yokes putting stress on the neck, resulting in fractures.
I sincerely hope you got rid of that old set, and replaced it with a newer one - which will allow connection of all modern external equipment. TVs made in the 70s, especially K9s and K11s no longer comply with current electrical safety standards.
Posted on Apr 15, 2011
Bpl tv model no. CV21AF33 data note store
Main system control memory IC (24C**) fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Before replacing it, check whether AGC voltage is correct [changes according to reception of channels]. Auto-tune in and check this voltage. It should vary when a station is tuned in. and when the search will advance. If not, the tuner too should be checked.
Dec 15, 2014 | Televison & Video
What do i do to change from manual to auto channel set up?
It is very simple, open the tuning menu select auto search option and proceed to auto search.
Sep 10, 2014 | Televison & Video
Increas channel capacity in bpl prima tv
BPL Prima has the capacity of 100 programs only. There is no other way to increase its capacity.
google.com/+GopakumarGopalan Gopakumar Gopalan Google
Apr 10, 2014 | Televison & Video
Auto set BPL channels
What is the exact model number to your BPL TV?
Mar 01, 2013 | Televison & Video
Not getting all the channels provided by the operator in old bpl tv
BPL quatra focus have a tunner which doesnt support S band and Hyper band. If you have to get allmost all channels then you have to upgrade the tuner. Tuner is component inside the TV to wich we attach the antenna or cable. There is no other option other than replacing the tuner. Replace a tuner with S band and Hyper band capability. If you need any more assistance feel free to contact by fixya. Tuner will look like one in the picture wich you will find inside the tv.
Jun 16, 2012 | Televison & Video
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
May 09, 2010 | Philips Magnavox MT1905B 19" TV
Problem solved!!
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sep 11, 2009 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
