Question about Garden
I have purchased a used 21A-422B129 rear tine tiller. It is missing a tine depth adjuster bar. I don't know the part number no do I know where to find one. Any Ideas?
The part adjusts the tine depth and is located above the encasement for the tine's
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
2 cycle tecumseh missing and white smoke
Try adjusting the carburetor to a richer mixture.
Dec 14, 2013 | Yard Machines Tecumseh 148cc Front Tine...
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 | Garden
TROYBILT BRONCO REAR TINE TILLER Model#21A643B066...HOW DO I CHANGE MY ENGINE OIL?...WHERE IS THE DRAIN PLUG LOCATED?
The drain plug is generally located on either side of the engine near where the block bolts to the frame of the tiller. It can be a square headed plug or an allen socket head plug.
Feb 12, 2011 | Mtd 21a 643b066 Bronco Rear Tine Tiller
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Jan 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
