Question about Frymaster Dean FPEL4 Deep Fryer
Orange flame Black suet buildup
The opening of the jets is too large. solutions:
1. Replace the jets. 2. Remove the jets and fill the holes with tin solder in common use in plumbing and drill holes. They recorded with numbers the size. the bit to be used to make the hole indicated. For example, a hole was drilled # 56 with # 56 drill bit. The correct size of hole is determined by the pressure and volume of gas, so re-drill this hole is not too difficult process. Given that the smaller sizes are equivalent to drill larger holes, the holes for natural gas range from # 54 to # 31, while propane holes ranging from # 62 to # 48. Opening experience from the smallest size using a sharp rod 1/16 "as a needle or ice pick. If natural gas or LPG Propane Butane. In no high-temperature jets for the gas outlet and not the cooled pewter melts. fully open the floodgates air. There adjustable jets, they have insert a needle to rotate open or close the hole. My job is that for 8 years have modified fryers. Luck.
Posted on May 09, 2016
  • 1,140 Answers
A orange flame means that not enough air is mixing with the gas to produce a nice clean burning blue flame. Try cleaning out any deposits of grease or anything else that could be blocking the air pathway to the flame.
Posted on Aug 29, 2015
Flame burning too orange
You need to get a Plumber or Appliance Tech to come out immediately and check the fuel to air ratio. You are not burning your fuel at the proper mixture. A blue flame is good, yellow-orange is bad.
Normally this is because the burner area is dirty or the pressure regulator may be set too high/low. The black marks are a sure sign that your ratio is too rich and it's just going to build up more soot and become unhealthy and dangerous.
http://inspectapedia.com/plumbing/Gas_Flame_Noise_Defects.htm
Don't wait...
Mar 27, 2014 | Water Heaters
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
How do i get all 80 i points in island flyover
its a little hard to recive all of the points. you can click on 1 button to shot a blue flame. if you will see a orange flame after you shot your flame, go to the orange flame. the plane that shooted the orange flame will help you to find some points. the 80 points are all around the islands.
Sep 09, 2012 | Nintendo Wii Black Console
How can I make my own suet cakes for feeding birds with?
Suet cakes are great for winter feeding. They will provide birds with the necessary amount of fat to help keep them warm during the colder months. Making your own suet cakes does not have to be a daunting task. I have found you a few simple great recipes that you can use.
http://www.gardenersworld.com/how-to/projects/wildlife-gardening/how-to-make-fat-cakes-for-birds/34.html
http://www.ehow.com/how_2054002_make-suet-cakes-birds.html
http://birding.about.com/od/birdfeeders/a/simplesuet.htm
Aug 29, 2012 | Allied Precision Birds
In regards to types of bird food, what is suet?
Suet is a type of bird food used to attract insect-eating birds such as chickadees, mockingbirds, warblers and kinglets. The suet is usually formed in to lard filled cakes and given to birds for food. Here are a few great brands worth checking out -
http://www.cabelas.com/product/Birdola174-Suet-Cake/1084977.uts?WT.z_mc_id1=43000000153261679&pcrid=15757538718&WT.srch=1&WT.tsrc=PPC&WT.mc_id=google'hom_Outdoor+Furnishings_Lawn+Garden'USA&rid=20
http://www.petsmart.com/family/index.jsp?categoryId=2769116
How do I make my own bird suet?
Here is agreat low cost recipe with step by step instructions for making your own birdsuet cakes http://www.instructables.com/id/How-to-Make-Bird-Suet-Cakes/?ALLSTEPS
Jul 24, 2012 | Birds
Apw gas grill causes black suet
All indications are there could be an issue with your burner(s). Check for a blue flame. If the flame is yellowish, there's an issue with air/gas mixture. This would tend to cause flare ups and scorch the food. A thorough cleaning of the burners should resolve this (see attached youtube video)
Also, check all surfaces for any residue grease. Left over grease will burn hot and create the soot you've described.
Sep 26, 2011 | Apw Wyott Ggt 36H Thermostatic Controlled...
I have a whirlpool gas range with 4 burners on top. one of the burners turns all the pots black, and the flame is really orange. Is there an adjustment of some kind? I live in Kenya where we use LP gas. ...
Yep! have a qualified repairman do the adjustments. You do not want to go Boom!! This problem is caused by improper air to fuel mixture. The orange flame and blackened pots are prime indicators.
May 10, 2011 | Whirlpool SF3020SKQ Gas Kitchen Range
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
Problems with black ash clogging up my flame tubes
Hi, If this is a new fryer it probably has the wrong gas jets in it. Probably set up for natural and using propane. Could be the gas pressures not set right on the valve. If this is the case, call your gas company and they will probably check it without charge. If it is a fryer that has been in use for a while and this problem just started you probably have a leak in your tubes to where oil is leaking into the flame area and the fryer will probably have to be replaced. It may be able to be welded if you have a good welder and he can find the leak in a place that can be welded. Good luck, kstfas
Dec 04, 2006 | DeLonghi D14427DZ Dual Zone Deep Fryer
Frymaster Dean FPEL4 Deep Fryer Logo
238 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
