Question about Kenwood VR-2080
On kenwood 2080 what is the difference between sl16 and xs8
Need to know b4 i hook it up
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
I would like to know if an mp3 play can be hooked into this unit
You need this adapter or one like it:
KECA-C1AUX
Search Kenwood aux adapter on eBay or Goggle
heres tha manual to download:
http://inform3.kenwoodusa.com/manuals/KDC-MP225.pdf
May 30, 2009 | Kenwood Sirius KDC-MP225 CD Player
Hook up
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_ This link should get you to the right place if not let me know and I can let you know how to get there. Good luck
-Andrew Hawkins
Aug 28, 2008 | Kenwood KDC-MP4028 CD Player
Kenwood system with tuner, cd player, casette player,intregrated amplifier and stereo power amplifier
This website sells the owners manual for $9.99 and the service manual for $14.99 your stereo:
Here is the website:
http://www.user-manuals.com/advanced_search_result.php?keywords=KA-996&x=11&y=15
Hope this helps.
Could be too many different reasons for no/low output. My 1st guess would be the output transistors, but that again is guessing without knowing more info about the receiver.
Hopefully, its is something simple like the way it's hooked up, or if you have the wrong channel selected.
Good luck.
Feb 02, 2008 | Audio Players & Recorders
How to turn on Kenwood KM-Z1 amp with SL16 input
Have you plugged the amp into the AV9000. Check if the outlet you are using is switched or unswitched. Changing the outlet will most likely do the trick.
Jan 12, 2008 | Audio Players & Recorders
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Kenwood VR-2080 Logo
67 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
