Question about HP Computers & Internet
Zoostorm computers orange flashing light and noisy fan
What is the orange light on the front of a zoostorm pc?
Could be anything. If it blinks a lot its probably a hard drive activity light. If its only on when you power on the laptop its probably just a power is on indicator or if it changes color when you plug in the power. Power status light.
Jan 16, 2015 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Computer wont turn on orange flashing light on the power button
Here is a web site that may help solve your problem.
http://www.randomfix.com/2007/04/19/dell-dimension-%E2%80%93-flashing-orange-power-light/
Oct 23, 2009 | Dell Dimension E510 PC Desktop
Fan runs but no boot
your motherboard is the problem. you should get it checked out at a local computer store.
Aug 22, 2009 | HP Compaq Presario SR2011WM PC Desktop
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
