Question about Bose Audio Players & Recorders
Battery corrosion i cant get the side off my beats cap to twist off. i really need to know how to gett it off with this battery corosion
3 Suggested Answers
SOURCE: Samsung beat twist unlock for at&t
Get unlock code for Samsung Beat Twist from Mobile-unlocker.com and unlock it from AT&T network lock.
Posted on Jun 03, 2013
ineedabin50249
  • 755 Answers
SOURCE: I have a 2001 Workhorse 8.1 Liter Gas Engine that needs a Coolant Recovery Tank and Cap. Does anyone know if the cap is a snap on or twist off?
if it has a pull tab on it it is a pull cap if it has grab ridges on it it is turn type ,, if you read the top of it it will tell you how it opens ,
Posted on Oct 03, 2014
Can corosion on a battery keep it from starting or getting rightncharge to jump vehicle
Yes, is the short answer.
Excessive corrosion on a battery's terminals, or dirt between the battery's two terminals can actually consume power. All corrosion should be removed. Some advise to smear vaseline on any terminals and connectors, to reduce corrosion buildup.
Nov 07, 2012 | 1999 Ford Windstar
I have a 2005 pontiac grand prix and the on dash screen said the front driver side turn signal was out, i change the bulb but the blinker still wont work there was some kind of corosion in the socket...
Sounds like you are on the right track...as any corrosion is in the socket...the bulb does not make adequate contact...with the bulb removed, spray the inside of the socket with PB Blaster...after a few moments thoroughly clean scrape, and wipe out the inside of the socket...with extra effort this usually works...also when re-inserting the new bulb be sure to use bulb lubricant...this will help to reduce the corrosion from coming back...you can completely replace the socket if necessary...from a salvage yard, or you can purchase new at the dealer...The salvage yard socket is probably $5. the dealer socket is about $25...Hope this helps.
Apr 01, 2011 | 2005 Pontiac Grand Prix
USB port corrosion
find a corosion removing spray, turn the power off before spraying, use the ear cleaning buds for cleaning, make sure the port is dry before turning the power on.
Mar 04, 2010 | Computers & Internet
Wiring schematic for plymouth grand voyager 1995
Is there green corosion on the tip of the wire ? Chances are the answer is yes. You will have to detach the fuse panel/box and run a new wire and connector to the fuse panel. Splice into the wire you can see, but make sur you cut enough of the wire off to get rid of the corrosion.Hope this helps.
Jul 30, 2009 | 1995 Plymouth Voyager
Trying to replace u-joints on a 2006 f-350 4x4
Hello , you really need to carefully beat the hell out of them. Choose a side remove ,both e shaped clips and hammer it down. This will push the other side out , thus allowing you to remove the bearing cap and continus hammering until out. This worked on my 1989 F250
Jul 25, 2009 | 2006 Ford F 350 Super Duty
2000 ford truck starting problems
most likley the positive wire has corroded off the starter. look at the small red wire more closely, if theres alot of corosion, replace the wire (and starter if needed) if you dont see much corrosion give the wire a good tug just to see if it really is hooked up well. you should disconnect the batt. before doing any of this.hope this helps and good luck
May 25, 2009 | 2000 Ford F150 Flareside SuperCab
Car does not Start in the Morning.
try the spark plugs or wires and the dist. cap
and rotor (cap and rotor might have build up or corosing
Feb 04, 2009 | 1990 Dodge Grand Caravan
Tire troubl 95 geo prizm
what happens is there is corosion that is holding the rim to the hub with the lug nuts off you need to break the corosion by giving the tire a hard donkey kick. if that doesnt work take a large hammer and beat on the outter rim to break it loose.
good luck
paul
Jan 02, 2009 | 1995 Geo Prizm
Playstation 2 problem with both consoles
Hi look where the controlss plug in and see if their is any corrosion if not take the case off witch is relitively easy to do just make sure you undo all screws some are under neat rubber bungs then check where the control ports are and check for corosion if it was corosion i cant see both going at same time unless circuit board got wet so check with magnifying glass for sines of water damage let me know how you get on ok
Jan 04, 2008 | Sony PlayStation (PS) Console
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
