Question about Hasbro Big Hugs Elmo
That's too tight
The doll says nothing but that's too tight.
Jessie doll string in the pulled position
Sometimes you can get the string cord to release and retract back. Hold the doll firmly and gently pull the string out about an extra two or three millimetres (eighth of an inch) or as much as possible. Keep the string tight for a short while and then allow it to retract slowly. It may take a few attempts, the skill is in pulling the string that little extra distance, holding it for a few moments, then slowly releasing it again.
Dec 30, 2013 | Toys
OIL LEAK ,HAS NEW GASGET BOLTS &FILTER ARE TIGHT. HELP
What car is this? Also, you have posted in the Dolls and Toys Category.
Dec 18, 2013 | Toys
How to turn the Barbie doll on
Make sure that the battery is charged and is seated properly.
Nov 30, 2013 | Mattel Barbie Video Girl Doll Blonde
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Dec 04, 2012 | Little Tikes Cozy Coupe
Speedometer doesnt work but cruise does on a 2003 379 550 cat 13 speed have swapped out the head unit same problem, where do i start.
You need to replace the speed sensor. When replacing the sensor you need not to thread tight. Gently thread till sensor comes to a stop. Back off one half turn then tighten outer flange nut tight. Plug back into harness and secure. Hope this fixes your problem.
May 15, 2011 | Jada Audiobahn Peterbilt Truck Trailer...
Just took her out of the package, put is NEW batteries the correct way, pressed the reset switch for 5 seconds and she does nothing! HELP
My daughter's doll is a couple of years old, we changed the batteries and she would not turn on. Finally held the reset button down for about 30 seconds and she came right on! Happy girl!
Dec 21, 2010 | Mattel Little Mommy Walk and Giggle Doll
Mimi doll by Remco will not sing, how to repair her sound box?
you must contact a "Chatty Cathy" doll expert who specializes in voice box repairs.
Jun 19, 2010 | Toys
Chain wont stay on
Did you replace the chain with a new one ? If the chain is to big for the sprockets than you need to purchase a link remover from anywhere that sells accessory's for bikes.
Remove one link at a time untill the chain fits perfectly.
Post back if you have further info. Thank you for choosing Fixya!
Mar 21, 2009 | Mongoose Toys
Hasbro Big Hugs Elmo Logo
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
