Question about Engines & Components for Chevrolet Chevy
How to set timing
Starts hard
    Sergeant:
  • 462 Answers
If newer vehicle camshaft and crankshaft sensors
Posted on Sep 07, 2014
Ignition timing set
The flywheels are keyed on the Husqvarna chainsaws, there is not way to change the timing. I would suspect you may have some carbon build up causing the hard start. Is the saw hard to pull over with plug removed?
May 04, 2014 | Husqvarna Garden
One link CCTV the hard drives showing the blocks of data but the time and dates showing zero and when I try to play the video its blank the date on the screen shows a different date to the set date, the...
Possibly a corrupt hard drive or sometimes when you change the time on them or the date they don't like it. have you changed the time or date lately? i would format the hard drive and start a fresh providing you don't have any important info on there.
Feb 18, 2014 | Washing Machines
Hard time starting 2004 Kia Sedona
Mu Sorento was hard to start. Eventually I noted that the coolant level was very low. When I filled ti, car started really fast. Another, hard to start, the brake fuel was very low, filled it and it started real fine. A coincidence or are there alarm settings there?
Jan 25, 2014 | Cars & Trucks
Hard starting cold
valve timing is off, when you set timing did you turn it over by hand then four times to make sure the timing marks all were correct
Nov 30, 2013 | Suzuki Tempter GR 650 Motorcycles
What does it mean when it starts up in a black screen and cant start the normal windows
warning suggests that user is required to immediately backup all data and replace the failing hard drive with a new one. Hard drives may go bad due to mechanical component failure, electronic faults or firmware corruption.
May 11, 2013 | ASUS Eee Box B202 PC Desktop
1989 lesabre stumbles and dies
I agree it sounds like the magnet for the cam sensor, or a problem in the wiring harness.
I don't think the engine will run with the cam sensor disconnected since it needs that signal to set base timing. It can run without the crank sensor once the engine starts.
There is a slight chance the timing chain is getting loose and affecting cam timing too. You may be loosing plastic teeth on the cam gear.
Apr 08, 2013 | Buick LeSabre Cars & Trucks
I just replaced the timing chain set on this 02 Durango with 4.7. Now it is hard starting, jerks under load and sets codes 340 and 344. I didn't touch the cam sensor during the replacement. I know the...
You must have your distributor out one tooth. Or else the chain is out one tooth. When you aim a timing light at the mark, if the mark is jumping around, your chain is wrong.
If neither of those, then check your firing order, and make sure all the plug wires are on firmly, and are not damaged.
Aug 16, 2010 | Dodge Durango Cars & Trucks
1987 Buick Electra Hard Starting
Timing gear may have lost its teeth. Sounds like it has jumped a tooth or so. Common problem on 3.8 vin code 3 engine for 87. To replace it you will need a front cover gasket set,timing ger set,new design tensioner,cam thrust spring & button and magnet.
Nov 23, 2009 | 1987 Buick Electra
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
